We need a few more details
Graphic card you use(single, SLI?), and the purpose of the system. Purely gaming? Video editing? Photoshop?
When i had an amd system with a six core 1100T at 4.20GHZ i would see bottlenecking quite a few times, only 60-80% GPU usage on BF3, Skyrim etc... so getting an intel based system i.e i7, sandy or ivy would lessen the bottlenecking.
Any recommendations on an intel cpu can you link something? And would I need to get a new PSU?
Something along the lines of this will do you.
Re-use your old RAM and your current PSU will be fine
What's your budget?
What's your budget?
What's your budget?
Oh yeah, also, will that MOBO fit into my antec300? Cheers.
Yes mate, it takes a full ATX board.
What Gpu are you using at the moment?
+1 just upgraded from a phenom II 940 to the above (cpu anyway), i got the MSI z77a-GD65)and it's great, got it running @ 4.2GHz with loads of room for morebut even downclocked to 3GHz like the stock 940 it's faster
I have a Phenom II 955 BE with a HD5770 runs every game i play easily enough at 1080p, i was going to change to an i5 but what is the point lol all you really need is a GPU upgrade, i would save your money until your CPU starts struggling. Then upgrade to intel.
That is what i intend on doing.
as a comparassion moving from 1090t @ 4ghz to an i5 @ 4.7ghz using the same 8gb of ram and the same card @ the same clocks [7970] my 3d Mark vantage score [graphics] moved from 29k [amd] to 41k [intel]
which proves that the 1090t was bottlenecking my card. i can only speculate but would expect you to see quite a large improvement
What's your budget?
id still wait till intel bring out there new CPU its not going to be that much of a bottleneck going from what i have just googled, but hey ho.
