~ Corsair Liquid Cooling CPU Bundles ~
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Starting today, we have a promotion for a few weeks where all customers buying High Performance Corsair Liquid cooling system and an Intel 'K Series' CPU are able to buy their Processor and Cooler together and net a nice saving.
Paired with out two most popular Corsair cooling solutions, the formidable Ivybridge CPUs are kept under control and overclocking potential is increased.
Corsair & Intel Hydro Cooler Bundle - Corsair H80 + Intel i5 3570K OEM @ £253.98 inc VAT
Chosen for ultimate cooling performance with an attractive bundle discount, the Corsair Hydro Cooler Bundle offers great value with superior performance.
Only at Overclockers UK!
Corsair Hydro H80 High Performance Liquid CPU Cooler
Corsair Hydro Series liquid CPU coolers provide a compact, easy-to-install, and maintenance free alternative to bulky, noisy air coolers, efficiently cooling and protecting your high-performance Intel® or AMD® CPU. The H80 features a double-thick radiator to maximize the surface area available for heat dissipation and dual performance matched fans.
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM
Intel's new IvyBridge based CPU's is a refresh that requires socket LGA1155 mainboards based on Intel Z77 Chipset. This new platform uses less power and has vastly superior integrated graphics. The HD2500 graphics is capable of all multimedia task featuring DirectX 11 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD4000 onboard graphics which feature multiple times the horsepower of the previous generation HD2000 making them ideal for gamers and have support for 3D Gaming. The new IvyBridge K series processors also feature immense overclocking as well.
- Lithography Process: 22 nm
- Cores: 4
- Threads: 4
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated HD 4000 Graphics
- Integrated Graphics Frequency: 650MHz (1150MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 1333/1600/1600+ MHz
- TDP: 77W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
By buying this bundle you save £5.00 (6.00 inc vat)
Only £253.98 inc VAT.
ORDER NOW
Corsair & Intel Hydro Cooler Bundle - Corsair H100 + Intel i7 3770K OEM @ £336.37 inc VAT
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler
Featuring a full 240mm radiator and two performance matched 120mm fans, the Corsair Hydro Series H100 extreme performance liquid CPU cooler is designed to deliver cooling performance that meets the needs of even the most demanding performance enthusiast.
The H100 fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles
Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- Cache: 8 MB shared L3
- TDP: 77W
- Socket: LGA1155
- 1yr Warranty
By buying this bundle you save £8.00 (9.60 inc vat)
Only £336.37 inc VAT.
ORDER NOW
Im to much of a wuss to try water cooling, putting liquid next to all my expensive hardware seems like a silly thing to do. If i was rich id totally do it though, the liquid cooled setups look badass
These closed loop liquid coolers take out that worry from the equation. they are totally sealed.
that way, your hardware is completely safe :)
Personally i trust these enclosed loops as i have had a couple in the past, but if it does go wrong do they provide some sort of insurance on your components if it leaks onto them?
simply put, they dont leak.
we have sold 100,000+ sealed watercooling units since they became popular and the return rate on them based on faults is very slim.
all of our stock is the latest revision.
we are tier one Corsair partners and every corsair product we list comes direct from them.
if there has been a revision to stock. OcUK will have it in our inventory :)
Nice deals. The issue I found with the corsair all in ones though, is that while they remove the danger of leaking, with the stock fans they were much noisier than a custom loop. Mind you they also cost quite a bit less :P
depends who the OEM was on the ones you had.
in honesty, your signature says you have an Intel Watercooler.
which are made by the same people who make the corsair ones... :confused:
Whats there to be confused about?
If both of my old Corsair pumps died in which they did do you think i would rush out an buy another Corsair cooler or would my sig show different MMmm. lol
They may be made by the same people but one says Corsair an the other says Intel on the package, an the Corsair were/are a lot louder than the Intel.
This one is roughly 2 month old and so far ive no problems with it (fingers crossed)
They may be made by the same people but one says Corsair an the other says Intel on the package.
The reason he added the confused face is because it's like going to Vauxhall and buying a Corsa, it having a fault and you going off on one and vow never to buy one again. Then you go on holiday and buy an Opel.
Well for one at the time of purchase i wasn't aware that they were made by the same company, so if id know i would have brought different ;) thats probable reason why it don't say made by Corsair on the box,but unlike the corsa or
astra they both say Vauxhall on there packaging so thats an anal comparison.
An me saying ive had 2 die on me (pumps) is not going off on one lmao, its called personal choice ;)
Funny thou because the Intel seems a lot better built imo.
My first one the pump started to make a grinding noise then gave up the ghost (13 months old)
My 2nd one made the grinding noise straight out of the box,wasn't purchased from Ocuk, big mistake on my part :(
Brought from a well known Pc fair, an because the cooler had been fitted/used they wouldn't refund or exchange it.
But like rjkoneill pointed out i suppose it does depend on the OEM.
I had loads of them in the space of a month or two.
seems like you guys must have been massively unlucky.
the return rates on enclosed loop liquid cooling solutions are the lowest out of all of our heatsink offerings.
