- 26 Dec 2005
- Paisley
I picked up a PC off the MM at the weekend, all housed in a 600t. The noise!
Im finding the noise unbearable, having to shove the PC away under my desk, even with the fan turned all the way down I find it pretty oppressive.
As I didnt build the thing, Im a bit unsure on what the fan connectors are for these big 220mm fans, can I just reverse the pins to make them 7v?
Can you replace these big fans with quieter ones pretty easily?
Would a bespoke fan controller reduce the fan speed further than the onboard dial at the front?
