Once you have installed TRIXX
https://www.sapphireselectclub.com/ssc/TriXX/TriXX.aspx
Scroll down, what you should see there is VDDC, ignore what it says in mine your does not go that high.
First overclock the core without any voltage increase and use this
http://unigine.com/products/heaven/ to stress test. how to stress test is to click run and then hit F9 when it starts, that will re load it for a bench, let it run the full cycle.
If it crashes during benching your overclock is unstable, it will go black for a few seconds and then stop, you will get a driver crashed error, reboot the computer and set the clock where they crashed and add some volts to it, 30 / 50Mv and run it agin. if it crashes again you might need more volts.
Do this in 20 / 25Mhz increments.
Don't go to high on the volts, i have 50mv left before it maxes out. that's perfectly safe for 24/7 use, you should only use max volts for benching points and even then don't do that all the time.
