New toy ordered from Digital Rev, funnily enough it has a 3 in it's name![]()
Wonder what that is? lol
There is no modelling lamp, just strobe itself, the constant lights are corner LED lights which are always the same daylight white colour.
Like I said, the results have been consistent so far, I don't know how to better clarify that.
Yeah both were shot RAW, imported into Lightroom and exported straight to JPEG 100% quality.
I've done samples at 24mm using the Nikkor 14-24mm lens and the Canon 17-40 L and found similar results although the 17-40L isn't as pleasing out of the box at the same aperture (f4) due to the lens being prone to CA wide open and the extra wide angle distortion.
The 5D has one touch AF modes, I particularly like one shot AI Servo, just hold the one touch custom button so get into AI servo, let go to go back to one shot.
I think he means the itch![]()
Are you comparing 100% crops or something rather than D800 files at the same output size as the 5d?There are differences here and there between the two though but nothing that the average person will ever be concerned with. The sharpness and detail at higher ISO is greater on the 5D3 with less noise but some of the mechanics of the D800 are better like navigating images in the playback screen, the arrow controls respond quicker and scrolling is smoother when moving around a zoomed in image.
Why are you not using lossless compression?The 5D3 RAW images are 30 odd MB depending on the ISO used whereas the D800 ones are 75 odd MB so new consideration needs to be made for memcards and storage as well![]()
