It's down to the individual to pursue the Supplier and determine what is and isn't a reasonable timescale.![]()
Actually its the supplier that determines what a reasonable timescale not the individual as thats just silly.
Your PSU may be fine.
I've had pretty much the same thing where a surge caused it to instantly shut down/reboot accompanied by the 'pop' sound which obviously wasn't the sound of anything exploding. It's the same sound you get when you switch on a decent hifi amp.
I also had the same message pop up on reboot.
Haven't had any issues since.
Seems like the auto surge protection did it's job.
You could always try switching it on again![]()
Useful info guys, but we haven't established that the PSU IS faulty yet
From the description, it sounds like the surge protection did what it's supposed to do and kicked in to stop any damage occurring.
Thanks for all the replies guys. This is why I use the OCuk forums.
If my sleep starved memory serves, it did sound very similar to an amp been turned on but the 'pop' sound occurred simultaneously with the shutdown, not the reboot. Just thought I should clarify that. I'll address the last bit of your comment in the following-
I do hope that the surge protection did it's job. It'd be a bit of a kick in the conkers if it didn't as I've always preached not skimping on the PSU for this very reason. Establishing the health of the PSU is my goal at the moment but this has bought into sharp contrast my lack of knowledge in certain areas. So, fellow OCuk'ites (yes, I'm coining that word), is there any risk with simply turning it back on? Should I disconnect my GPU and SSD's/HDD's first (other than the boot drive)?
After reading up a little on the subject, it does seem that some people think that not only is ASUS Anti-Surge a gimmick but a gimmick that can be overly sensitive, causing it to detect surges during normal operation. There are some threads that match my story almost exactly even down to the CPU, a mobo from the same model line and a Corsair AX series PSU. Sometimes the thread ends with Anti-Surge being disabled and everything being fixed but then, some end with the issue only being resolved after the PSU is replaced.
I hope I'm not waffling.
So, what's my course of action fellow OCuk'adians (I might go with that instead)... just switch it back on?
Sorry, I wasn't really clear. The pop was also simultaneous with the shutdown in my case too.
I can't guarantee anything for you, but I can say that after initially crapping my pants when I went through exactly the same thing, just switching it on again showed that nothing had been harmed.
Oh, and they may be right about Asus surge protection being a bit oversensitive. My PC is plugged into a decent 4-way surge protected socket which didn't bat an eyelid...
I understand mate, I've been there. It happened to me within a week of building it.
If you're really concerned, try the paperclip test posted above.
have you removed the cmos battery to fully clear the cmos?? leave it out a good 30minutes and then try,psu might be fine
If you read the Asus forums there are many people complaining about this feature causing issues even after replacing the PSU. The general advice is to simply disable it in bios.
yeah if its corrupted,so would loading optimised defaults and re entering any bios settings
Anti-surge device is dependant on hardware on the motherboard. If that hardware has not been calibrated, then even the 'anti-surge' message may be deceptive. Essential is to first confirm those BIOS numbers with an acutal multimeter. 3.5 digit meters are are even available for a few quid in Maplin.I entered the BIOS and the 3.3, 5 and 12 volt levels were all within tolerances.
The thing reported as a 'surge' is completely different from something else (also called a surge) that the Belkin will magically eliminate. Too many only know using word association. Therefore fail to appreciate the word 'surge' describes many different and unrelated anomalies.
Are those BIOS numbers correct? Post those numbers. Each can be within ATX Standard limites and still be defective. Details provided with those numbers.
For this purpose, any 3.5 digit multimeter will do. One can spend plenty for additional features (ie temperature probe). But for this, a basic 3.5 digit multimeter (voltage, current, ohms) is more than sufficient.I'm not sure what you mean by "Details provided with those numbers".
The word 'surge' describes at least three completely different electrical anomalies each involving different circuits. Your 'plug' is completely irrelevant to what the OP has asked about.A surge protection plug is not sensitive enough to detect small spikes, and these smaller spikes can cause damage over time.
So a surge created by a USB device would be solved by a device on the AC plug? Hardly. Another example of the same word describing two completely different snd unrelated disturbances. The word 'context' applies.
