Evga 680 Overcloking
Okay bud all makes sense now :D I wish id have asked the question yesterday instead of moving away from it. Like you say, at the very least i will have two good fans that i can reuse.
Axeman, Been running the computer without the case panel on since last night, didn't seem to reduce any temps. That been said i do like looking at the 680's :) but cats and open pc's don't mix :D
Just to confirm the push/pull method did the trick bud, much appreciated for the advice, i believe it now runs full loads with prime95 at about 72, which i think is acceptable.
I have since been offered a good amount of money for my cooler from a friend so the plan now is to upgrade to the corsair h100, buy an extra nzxt phantom 200mm fan and use this as my push/pull.
great stuff mate
remember you will need 4 fans for the h100 to get the best out of it. you will want them to be the same as youve good also :-)
also how do you mean extra 200mm fan? push/pull is needed for radiator cooling only.
