They have a WMIC, tucked near the passenger side arch.
It depends on what your preferences are, I'd get one with some mods already, yeah, but given their age I'd buy on condition. They are starting to rust now so you need to be wary of cars that are hiding a lot of rust, particularly around the rear subframe mounting points. Other common problems are subframe bushes and turbo lines and VVT rattles. Lack of oil changes (already mentioned in this thread I think) using incorrect oils can lead to the oil spray bars blocking.
Modded 15s will be cost a fair bit to buy, a 14a would be cheaper and you could spend the savings on mods for the 14 and end up with a pretty similar car. The 15 does look nicer though.
didn't twitch or anything but it was like a rollercoaster!
