quite decent actually,its no reflection on a good clocker though,ive seen poor asic cards clock rather well and vice versa
Battlefield 3 is certainly better but damn MSAA hits AMD cards hard in that game.
have you overclocked it yet? you should be able to max the sliders in ccc overdrive without touching voltages ect
I don't think that will work lol. The core goes to 1400mhz in overdrive, stock is 1050mhz.
I just tried that with overdrive in GW2 and I wasn't sure if I saw an artifact. The game has texture flicker on certain objects. It only happened once while I was playing. I'll try afterburner. Should I use the force constant voltage setting?
