Having got into photography as a hobby I'm now wanting to invest in some decent lenses but I have been stuck trying to decide between two for awhile; the 17-55 and 24-105 (to go with a 10-22). If I'm going to spend a fair bit of money on lenses I just want to make sure I make the right choice.
Here's my thoughts so far...
Pros for 24-105:
- Build quality
- Focal range
- Can be used If I ever go full frame (that's if)
- Would be a better combination with the 10-22
Cons for 24-105:
- Not very wide on a 600D
- F/4 isn't great for indoor
- Not as sharp as the 17-55
Pros for 17-55:
- Image quality
- Fast F/2.8
- Good for indoors/ low light
- Wide enough for landscapes
Cons for 17-55:
- Build quality
- Same focal range as my kit lens
- Focal range crosses with 10-22
- Is F/2.8 that much different?
Any advice/experience?
Pros for 24-105:
- Build quality
- Focal range
Cons for 24-105:
Pros for 17-55:
- Image quality
- Fast F/2.8
Cons for 17-55:
- Build quality
