Let me aware you...
Just because you're too inept or so it seems in my opinion not that means much but hey to grasp the concept of brackets in brackets inside brackets and I'm sure we can add many more doesn't mean the system is a bad one!
I guess you're just as inept without as you are with them. :p:D
I spend half my day writing SQL so already use brackets when I post (mostly because it saves writing loads of additional new lines).
