3D printed pc cases
4 May 2012
What do you think the chances are of having OCUk start a print your own case section, perhaps hosting members designs and giving a little store credit when someone chooses to have one?
Could lead to some interesting cases and possibly some optimised SFF cases building on the leasons learned from the commercially available.
First one i have seen done from scratch, not exactly mindblowing but a proof of concept if nothing else.
http://www.shapeways.com/blog/archives/857-3D-Printed-PC-Case.html
very nice, i imagine they wouldnt be cheap though, could be a bit of a nightmare when it comes to designing it from an average persons point of view i.e coming up with designs that look good on paper but when it comes to putting it into practice they look bad, im not saying it would be a bad idea for ocuk to produce these, but would consider it myself if it were offered
Pretty good, but I see a possible problem.
Shouldn't the moulding to hold the graphics cards be at 90 degrees to the moulding for the motherboard backplane?
Ok so this may give an idea of cost. This is the cost from school.
Price of material: £3.52 per cubic centimeter
Price of printer: £15,000
We have one of these: http://www.uprint3dprinting.com/3d-printers/3d-printer-uprint.aspx
it sounds like your being done over mate, current costs are about £40-60/Kg or £0.30/m and the printers are in the region of £1-4k now.
Are you sure they didnt get one of those long term look how cheap it is this month but we will screw you to the wall for 20 years deals?
Got no idea haha :p
The machine itself we have had for over 2 years which may explain the cost of that. I doubt we paid that price for the machine as we tend to have much of our machinery donated or at reduced costs.
The material that is what we, the students, pay for projects of our own. I would assume that it is a system like that of inkjet printers. Forced to buy the filament from the suppliers and pay a premium for it.
It's not just the cost of the filament int he printing though. As its ABS there is also the cost of the curing chemicals ect...
There are a few different technologies. The one you are thinking of is extrusion, and is the realm of the home printers such as the UP! and the MakerBot. The pricey ones are far superior in the build, including finishes and ease of use. They can use resins, and sintering, but are not an extruded filament the way the cheaper ones are. The quality is miles apart.
Why would you need a 3D printer when you could use a cnc machine to cut out all of the parts you need and assemble it? :confused:
3D printing allows for much more complex shapes and hollow internals perhaps for cable routing. Every part can be made using the one machine and just setting it to print for a few hours. Where as with CNC you will find that a lot more manual intervention is required when producing complex pieces and many will be impossible using standard methods. With CNC you also have the problem of the high amount of wasteage that naupturally comes with it.
Also, as 3D printing technology advances it will become much much cheaper and the parts will be stronger. It is still very much in its early stages and, having witness the possibilites of metal 3D printing have no doubt that it will eventually replace many, other other manufacturing methods in the future.
Imagine things like taking your car to the garage and needing a replacement part. Instead of waiting for 3 days to get one shipped in, he downloads the files and prints on on the spot!
What I'm saying is, yes your right. For now it is is much cheaper to get parts CNC'd. 5-10 years time, who knows! You could hit print and have a fully assembled case without the hassle
