hm things to try
2nd pci-e slot on ur mobo
molex to 6pin if you have one
check bios see if anything is set wrong ><
fans spin on the card?
Yep fans spin on the card
Molex to 6pin doesnt fit in the power socket
In the bios its set to auto i changed to pci saved it it reset and goes back to auto
The cards in the pci express 3.0
