Upgrade from 6950: advice.
15 Aug 2011
Hey guys..
Currently running an MSI 6950, looking to upgrade to something a bit more powerful..
Spend is around £200 can come and go a bit with that if needed..
Usually playing @ 1080 with as much visuals as possible turned on..
What ATI card would you recommend?
Thanks
7870 starts at around £190 but it's not really much of an upgrade from a 6950 at all. To get any meaningful performance increase you need to spend £240-ish on a 7950.
edit: oh woops, you said 6950 and my brain read 6970. Yeah a 7870 isn't too shabby in some stuff then I guess, depends how much you can sell your 6950 for.
6950 vs 7870
6950 vs 7950
Hey guys..
Thanks
None really. had the same urges, but got persuaded it was a stupid idea and rightly so. Quite happy with my 6950 tbh.
