This is the only answer I could find from the forum you asked the original question. I asked them again and this is the reply:
http://www.transformerforums.com/fo...13-moisture-when-pressure-applied-screen.html
Video:
You are spot on on this one. The "moisture" look is a result from the digitizer glass coming in contact with the lcd underneath, putting pressure on it and distorting the image. With these tablets, there is a tiny space between the lcd and the digitizer. Because gorilla glass 2 is thinner than gorilla glass 1, it is slightly more flexible. In other words, it's easier to slightly bend when you press on it.
Video:
