Lian Li PC-A75X - PRE ORDER EXCLUSIVELY AT OCUK NOW!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
This is an amazing option if you require a large case with the ability to watercool and have many many hard drives.
Stock is due to end of October.
Lian Li PC-A75X Full Tower Aluminium Case - Black @ £199.99 inc VAT
Huge internal space fits HPTX motherboard, and graphics card, which can up to 360mm long, and there are room for 12 hard drivers. There are 3 x 14cm and 1 x 12cm cooling fans to cool the system down. It is an ideal for gamer and pro user. HDD installation can't be anymore simple and effective. Simply secure four HDD screws to the HDD, and push into the HDD cage runner, and lock in position. There is even room for 12! YES 12! 3.5" drives.
- Dimensions 220mm x 585mm x 590mm ( W, H, D)
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material:Aluminum
- Net Weight: 9.5KG
- 5.25" drive bay (External): 2
- 3.5" drive bay (External) None
- HDD bay 3.5-Inch HDD x12 / 2.5-Inch HDD x3 (Using 3.5-inch Bays)
- Expansion Slot: 11
- Motherboard Support: HPTX / E-ATX / ATX / Micro-ATX
- System Fan (Front): 140mm Fan x 3
- System Fan (Top): None
- System Fan (Rear): 120mm Fan x1
- I/O Ports USB 3.0 x2 / USB 2.0 x2 / HD Audio
- Maximum Compatibility: VGA Card length: 360mm / PSU length: 360mm
- CPU cooler height: 170mm
Only £199.99 inc VAT.
ORDER NOW
Love Lian-Li, extra loving the new black interior..but why no top fan slots? I'd have to cut it to get a Corsair H100 into it.
