Hi all,
I have a odd issue that I'm (an it professional) unable to fix.
you've heard what they sat about a plumbers taps always leak, well in a nut shell, I can't get any LAN connections to work at home.
This is my setup. I've reduced the amount of connected kit to try and work out whats happening and why;
PC (HTPC) running win7
PC (web server) ruuning fedora 16
PC (new HTPC) running ubuntu 12.4
laptop (MBPr) running osx (wifi)
appple tv2 (wifi)
xbox 360 (wifi)
as you can see, I've only got a couple of LAN devices in use. I do have loads of others but they're all disabled for the time being.
I've had to move everything to wifi as the LAN connections don't work.
I've tried every port on the router, I've tried 3 different routers (2 of them new!) I've used both dhcp and static addresses which is where it get even more strange...
If I set a static ip on the fedora box, it works, I can ping the router and get onto the internet, BUT only if i give it an address above .100??!???
the dhcp service on the router is set to scope from .2 to .254.
I've factory reset my router a biljilion times and sometimes, it'll work (lan device get an ip and can see the web) but as soon as i change any config, boom all stop again.
i'm at my wits end.
i can't find the common item thats causes these issues.
What i'm looking a for here is some other things i can test/try to try and pin down the cause.
any ideas/comments welcome.
thanks.
appple tv2 (wifi)
xbox 360 (wifi)
i'm at my wits end.
thanks.
