670 sli problem
Exe
Exe
17 Nov 2011
Hi, basically the problem is i can't do any sort of overclock or the cards will just crash not even +20mhz for example. Any idea what the problem could be?
have you plugged in two 6 pin connectors into each card? How big is your PSU, what brand is it, and what are the rest of your system specs? It could be a PSU problem, it could be a problem with your cards, it is hard to tell without more info ;)
Edit: you beat me too it with the PSU link but the rest of my questions still stand :)
Remove one card and see if you can oc the remaining card, them swap the cards and repeat. You may have a duff card
Also do the above to check the pci-e slots one at a time.
Quite possibly poor overclockers :( Do what Kaapstad said though and remove 1 card and find it's max overclock (run Heaven a few passes on benching) and then repeat on the other card. In SLI, I can't run to the same overclock as a single card but it is very close.
Bit of a shame really its the 670 ftw that doesnt like the overclock but my standard 670 goes up fine.
Chiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiip.
Maaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaatt
Give it a bit more voltage.
Oh wait .........
Waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay!
