Gigabyte 660ti minimum fan speed 40%
18 Oct 2002
Amsterdam,The Netherlands
Hello, I recently upgraded from a GTX280 to a Gigabyte 660ti.
The Gigabyte has two large quiet(ish) fans, I have found a way to change the fan speed curve with MSI afterburner but I can’t get it to run slower than 40% at idle, even if I select 30%
Is the minimum fan speed perhaps a BIOS setting that I can’t change with software or is there a program that I can use?
If it is a BIOS setting is it a case of waiting for a BIOS update that allows lower than 40%
Seems quite high for auto though, my 670 on auto was 30%. (Reference)
The fan profile should change to how you want it? Weird for it not to.
I can change the profile with MSI Afterburner, I just can't select a speed lower than 40%, if I set it t 30% it stays at 40%
Oh well, it's not that loud as the fans are quiet anyway, I just wanted to set them lower when they are not needed but I guess the minimum fan speed is in the BIOS to stop people roasting their card with a low fan speed :confused:
