Web-Site Error!!!
6 May 2010
Nottingham, UK
Hi Guys,
I wonder if you could help me I have built a web-site using Nuke Evolution Xtreme
and on the homepage there is a block for the last 6 posts on the forum that get
put into this block but the block is not updating and I am getting the error
message below in my admin logs. If anyone could help me out I would be grateful.
URL: /modules.php?name=Forums
File: /home/My Domain/public_html/modules/Forums/glance.php
Line: 97
Message: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')
AND t.forum_id = f.forum_id
AND p.post_id = t.' at line 9
Code: 1064
Query:
SELECT
f.forum_id, f.forum_name, t.topic_title, t.topic_id, t.topic_last_post_id, t.topic_poster, t.topic_views, t.topic_replies, t.topic_type, t.topic_status,
p2.post_time, p2.poster_id, p2.post_username, p.post_username,
u.username as last_username,
u2.username as author_username
FROM nuke_bbforums f, nuke_bbposts p, nuke_bbtopics t, nuke_bbposts p2, nuke_users u, nuke_users u2
WHERE
f.forum_id IN ()
AND p.post_id = t.topic_first_post_id
AND p2.post_id = t.topic_last_post_id
AND t.topic_moved_id = 0
AND p2.poster_id = u.user_id
AND t.topic_poster = u2.user_id
ORDER BY t.topic_glance_priority DESC, t.topic_last_post_id DESC LIMIT 6
There's nothing obviously wrong with your SQL, although without seeing your schema it's impossible to say for sure.
Have you added/removed some tables recently? Messed around in phpMyAdmin at all?
Hi Spunky thanks for your reply.
The only thing I have done lately on Myphpadmin was import an sql file for a
Ventrilo block on the site but the problem was there before I did that anyway,
so im pretty sure its not that.
Apart from that no tables or anything have been touched.
Sorry, just realised I'm being blind - you have an empty IN() statement:
WHERE
f.forum_id IN ()
There should be a list of values between the brackets.
WHERE
f.forum_id IN ()
That's funny m8, because when i looked back through the error that i just
posted i noticed it as well, I have added what is needed and the block is working
fine now lol. Feel like such a dumb ass lol.
Thanks for the help buddy
