Hi guy's
Bad day for me as had to call out the RAC earlier due to my car not starting after me and the girlfriend came back from shopping. Was just a loose battery connection so an easy fix. Jolly good we thought and went on our way.
Unfortunately crashed my car about 5 minutes after this and collided with a concrete central reservation after the tire burst because there was a load of rubbish on the road which i assume punctured the tire.
Was driving at 30mph so luckily no injury's and no one else involved. But while coming up to a corner my tire burst and i ended up skidding into the reservation.
Just seemed to be cosmetic damage at first so replaced the tire with my spare and thought all was good. Annoyingly tried to start the car up and once again it wouldn't as the battery had died so had to get my step dad out with some jump leads.
However as I set off I realised that sadly the damage wasn't only just cosmetic. The steering's completely off and its wanting to jump to the right, Its also making some very loud noises also the tire was boiling hot.
I checked under the car and it seems one of the bars that connect the car chassis to the wheel has crumpled when I slid into the concrete.
First question I wanted to ask was how much roughly do you guys reckon this will cost to fix bearing in mind I will need a new battery as well?
Also will it be best to go to some local family run garage or a place like kwikfit?
And finally am I required to inform my insurer even though I have no intention on claiming from them and if so will it affect my premiums?
Thanks for taking the time to read and any help would be fantastic as you can imagine im a bit shaken.
Its an old model Ford Ka btw.
