Bin the stock fan, it's seriously noisy. I'd recommend a couple of the Akasa Apache fans in push/pull, I've got this setup on my 2700k and it's cool and quiet.
having them intake or exhaust?
I use the H50, H70, H100 on different PCs, they are quite good as coolers but are never going to rival a custom water cooled system.
I always have the fans set to blow air out of the case as this slows the build up of dust in the rad.
The H50 I use has its work cut out for it sometimes. I use it for cooling an i7 975 which can really churn out the heat. The other day I had it oced to 4.4ghz and the H50 still coped.
yeah ill try blowing it our first, if its not any better ill try blowing it in, if the h50 can handle it at 4.4ghz, im assuming the h60 is slightly better, that'll be fine
I have 2, one in mine and one in my girlfriends. My pump has an annoying faint noise - can't really describe it. My girlfriend's doesn't though, I've never bothered sending it back.
i should mention that i have the h60 myself with an i5 3570k overclocked to 4.5 ghz and it doesnt go past 66/67c in prime 95In game such as bf3 it doesnt go past 55 ish
so yes h60 is amazing!
Stay away from these types of coolers, im on my 5TH h80 now within 12 months!!! Good job corsair let me change them. I would go with air cooling. Next time i change ill be going back to air.
). I also think they look much nicer than air coolers, and of course there's no danger of clashing with RAM etc.
Ive been running a H50 for about 4 years now and can't fault it, much better than a stock Intel HS/fan, knocks quite a few degrees off temps. (Mine is actually a NorthQ Siberian Tiger but its the exact same thing, their produced by Asetek then re-branded)
Same here -H50 4 years, been rock solid. Really surprised at actually how good its been. They are quieter than air (if you run push pull with decent 1200 mm fans & set BIOS to silent ), been a more constant, stable solution than an air cooler for me.
I would get another possibly the H60
