**A GAMING CAPABLE LAPTOP THATS CIRCA £550!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Yes with the new AMD Platform, this is now possible! :eek:
Not to the point where it will just play games, but it will play the latest games at medium-high detail settings too, which is quite an achievement, check it out:-
Samsung NP355V5C-S01UK 15.6" LED TFT, AMD A10-4600M 2.30GHz, 8GB DDR3, 1TB HDD, DVD Super, Win7 Home Premioum - Silver @ £559.99 inc VAT
Now there’s a notebook all the family can enjoy - the Samsung 355V. With the blistering power of the latest AMD quad core processor, loads of memory and 1Tb of storage you can get things done fast, while a flexible range of ports, an ergonomic keyboard with a numeric keypad and anti-reflective screen ensure effortless usability, so life’s much easier for everyone.
Features:-
- Powerful Performance - with the latest 2nd generation AMD quad core processor, 1Tb storage and discrete class graphics, even the most demanding applications won’t slow you down
- Exceptional Clarity - the anti-reflective LED display produces sharp images and bold colours, and has no mirror effect even outdoors or under bright lights so it won’t tire your eyes
- Outstanding Design - be a real style leader and the envy of your friends and neighbours with a fashionable, modern design available in a choice of vivid colours
Specification:-
- Screen Size: 15.6 inches (matte screen)
- Resolution: 1366x768
- Processor: AMD Trinity (A10-4600M)
- Processor Speed: 2.3 GHz
- Storage: 1TB HDD (5400rpm)
- Memory: 8GB DDR3
- Graphics: AMD Radeon HD 7660G & HD7670M
- Graphics RAM: 1GB DDR3
- Operating System: Windows 7 Edition Home Premium
- Gaming benchmarks thread on OcUK Forum: http://forums.overclockers.co.uk/showthread.php?t=18433537
- Review: http://www.expertreviews.co.uk/laptops/1294489/samsung-series-3-np355v5c
- Warranty: 2yr
Only £559.99 inc VAT.
ORDER NOW
Here is another guys, a bit less money, but it is also a less specification:-
Samsung NP355V5C-A04UK 15.6" LED TFT, AMD A8-4500M 1.90GHz, 6GB DDR3, 750GB HDD, DVD Super, Win7 Home Premioum - Silver @ £449.99 inc VAT
Now there’s a notebook all the family can enjoy - the Samsung 355V. With the blistering power of the latest AMD quad core processor and expandable memory you can get things done fast, while a flexible range of ports, an ergonomic keyboard with a numeric keypad and anti-reflective screen ensure effortless usability, so life’s much easier for everyone.
Features:-
Specification:-
- Processor: AMD Trinity (A8-4500M)
- Processor Speed: 1.9 GHz
- Storage: 750GB HDD (5400rpm)
- Memory: 6GB DDR3
- Graphics: AMD Radeon HD 7640G
- Wireless LAN
- 100/1000 LAN
- Integrated webcam
- 3-in-1 Card Reader
- 2x USB2.0 & 2x USB3.0
- 1x External VGA Port
- 1x Kensington Lock
- 1x HDMI Port
- 3-4hrs battry life
- 2.5kg weight
- Warranty: 2yr
Only £449.99 inc VAT.
ORDER NOW
how is this compared to an i5-3210M coupled with let say gtx 650M ? also anyone know if it has 2nd hard drive bay ?
I'd go for the cheaper of the two.
Both will game near the same level, if one can't offer decent enough performance, then the other would be pretty much the same.
I'd assume the Trinity would be the cheaper of the two?
Gibbo
I'm glad to see you finally have some more 'mid range' laptops in your inventory, the whole between super cheap and super expensive was widening!
I've been thinking about replacing my 10" Samsung netbook, Bradmax57 mentioned a 11.6" Version, are Samsung bringing out versions with smaller screens and will you be stocking them?
I'm not sure jumping from 10" to 15.6" in one hit is advisable?
Yea trinity is cheaper as the one i saw on the store was around 700 ish
I've just got one for myself, No second drive bay but it's a standard 12.7mm optical drive so I'm going to put the original HDD in there and put fit a SSD.
On the plus side only one screw to open to remove the RAM and only one more for the optical drive my acer is a pain I've lost half the screws.
