Mobo, CPU and 16gb mem – budget ~£450
3 Jun 2005
Starting to think about an upgrade for my main gaming rig. I’m thinking Z77 probably represents the best bang for my buck.
If you were buying, what would you go for?
Imo this, I have the same with the D14, but 8GB and it's plenty for me for gaming with 1GB as RAMDISK for pagefile and caches. Getting the 8GB version of this ram save you nearly £40 and can upgrade later if needed. Great ram, great motherboard! Mobo power phases run very cool, 60c max with 1.29v under load. Also has thunderbolt.
You can go much cheaper on the motherboard and ram if you want to save money, but you asked what I would buy, and this is what I bought!
The ram is also a great height as it's so bloody small, doesn't even go over the ram slot clips so perfect for D-14.
I would wait for Haswell if I already had an i7! Can't see much of an upgrade coming from a new CPU and motherboard. Maybe you should look for another GPU if you want gaming improvements?
I just won a 7970 Lightning - I wanted to upgrade the rest of my kit to roughly the same level.
EDIT
Quick question: Will I lose my RAID0 when I change mobo's?
EDIT
Of course you did, thought i recognised the name. Lucky so and so.:D
Don`t know about Raid0, can`t answer that one.
Yes he will.
Even if the controller is the same, I think it loses it moving to another.
The problem is most onboard solutions will only allow you to create a raid array and not import one.... I'm currently pulling nearly 1TB off my machine to upgrade it lol :(
Oh you lucky... :D congratulations!
If you must then the kit I linked is more than adequate. :D I have the same cpu cooler as you, same GPU except my 7970 is a cheap one with an Accelero 7970 cooler on it.
Kudos for not bragging in the original post. I would be all over that. :p
