Hi guys.
Apologies for a long post...
I've got a two questions here for you
Yes, I did my own research on it but didn't find too much info.
1. I purchased the GeIL EVO Veloce Hot-Rod Red 32GB (4x8GB) DDR3 PC3-14900C10 1866MHz Quad Channel Kit but was sent a 4x4GB kit so I RMA'd it. I'm currently awaiting the right modules to be sent.
Now the kit I originally purchased appears to be discontinued (product not found) on here and on other internet retailers but there is no info why. These seemed to be fairly fresh modules. Also the kit was 1866MHz, I still see the 2400 MHz version around.
Does anyone know why they have gone?
Maybe there were some issues with them that I'm not aware of?
2. I had the other 4x4GB modules at home for the weekend and I couldn't resist not to put one in (I have a fresh PC build and wanted to check if all other components work). So I put one module in and realised it was running at 1.65v even though they're rated at 1.5v. I've also heard lots of scary things about i7 3930k and 1.65v being dangerous so I didn't want to risk it and took it out. The mobo had the auto setting on DRAM voltage and all memory profiles had 1.5v on them too (checked through CPU-Z). The mobo is Rampage Extreme IV with the latest BIOS.
Any idea why that happened? (I'm weak on hardware atm, OC noob
Thanks for any suggestions
Yes, I did my own research on it but didn't find too much info.1. I purchased the GeIL EVO Veloce Hot-Rod Red 32GB (4x8GB) DDR3 PC3-14900C10 1866MHz Quad Channel Kit but was sent a 4x4GB kit so I RMA'd it. I'm currently awaiting the right modules to be sent.
)Thanks for any suggestions
(Hopefully)
