Fifa 13 Line down pitch?
25 Nov 2011
The KOP
Guys take a look at this quick recording I have done. Take note of just in-front off messi I get this line down pitch? when playing you can see the grass unfold type thing LOL Not sure on what the correct words I should be using here.
I posted this in Fifa Game thread but It can take ages to get a reply on there. IS this a game issue? do you guys also get this?
cant see the video says does not exist
It could be vsync as sometimes a game can conflict with control settings
have you tried looking for any cfg or fifa ini files that can be edited in my documents/my games ? also try forcing vsync to always on in ccc or nvidia and leaving the game setting to off
grass unfold sounds exactly like screen tear to me
Try forcing vsync in d3doverrider if it goes away you know it was vsync if not then obviously another issue
I'd also give the 12.9 beta cats a go if you are on 12.8
Am using 12.9 also with there cap and I have radenopro tried with and without that installed same issue will look at vsync.
