Best card for...
21 Jun 2010
I have a both a Sapphire 6950 (flashed to 6970 saders only) and a Sapphire 7950 - which I am currently using.
I upgraded from the 6950.
Is it worth me selling both cards and get something like 7970 or GTX670?
I am basing me getting £300 in total for both cards. I am mainly looking at running BF3.
I run the game on a Samsung SA750D monitor - 1920x1080 @ 120Hz so looking for best frame rates.
Other specs
i7 @ 4.2
Sabertooth Mobo
1200w Corsair PSU
Muskin Ram @ 2000Mhz
Is it worth the hassle of selling and upgrading or shall I just OC the nuts of the 7950 and pocket the cash for the 6950?
Thanks
how much slower is an oc'd 7950 against an oc'd GTX670?
Is there much in it for BF3?
I am only bothered about BF3 and want to get the most out of my 120Hz monitior.
Don't be silly.:)
There is no difference between them(that you will notice without a fps counter) when the 7950 is clocked, I sent a His IceQ 7950 back because the cooler was too noticeable@stock for me, I can't tell the difference between it and my 7970 in game at all.
Looking back, if I new for sure an AC Extreme fitted the His, I would have kept it, it was a decent clocker but my 7970 isn't.
Overclock the 7950 and pocket the cash.
As above.
Don't be silly.:)
All spot on :)
Great thanks for the guidance
I am assuming that ATI drivers have improved things with BF3 recently then as the benchies I have seem from some time ago showed the NV GTX670 to be high frame by quiet a bit?
The 12.9 beta drivers have improved performance on BF3 heavily. I am not sure about caps but I have read that the latest version will also improve performance, even if you only use a single card.
