Anyone got a razr i yet? Would like to know some opinions about it.
Yup .... I have one
Only had it a day and so far I'm keeping it. Bought off Clove and delivered yesterday. Early days.
Phone feels solid and sits nicely in the hand - after the slippery One X
Battery life it's too early to tell but looking good though being new will take a day or two to settle down and for me to stop fiddling so much
Signal reception is good to great. To be honest in the house it's only similar 90 to 100dBa as the One X but 3g works way better and signal never disconnects. Outside things are a good deal better than the One X. Been at a location today where 3's signal was poor on the HTC and could spend a lot of the day without sig. Razr i had no issues with fairly speedy 3g reception. Call quality is good and speaker has plenty of volume as does the 'external' speaker which is passable to listen to music though don't expect too much!
Screen is good and on a par with the One S. Tt has good colour saturation and is of a similar brightness so good to see in bright light conditions. The 'buttons' being on screen mean you lose a bit of screen space at the bottom unless watching a vid. Notification light is bigger and brighter than the HTC One phones.
The ICS operating system seems pretty unmolested by Motorola, which is a good thing. My last Moto phone had the horrible Moto-Blur which was a PITA at any time. The Intel cpu pushes what apps I have used along very nicely. If I didn't know better I'd say it had the S4 as per the One S. I'm using Quick ICS Browser and in honesty feels a lot faster than the One X and doesn't stall with multiple active tabs or task switching. Adobe Flash won't install or work but other than that the apps I use seem to run fine.
Swiping left brings up a quick settings page rather than the next desktop page. Wasn't sure about this as used to pulling down the notification bar for that. It has grown on me but the quick settings on the page is a little limited though you can go direct to settings off that page.
Bluetooth and GPS both work fine. BT connected straight to vehicle radio and worked as it should either for calls or to stream music. GPS lock was quick and accurate to 7 foot (so it said). Compass is surprising accurate compared to the one on my One X which was very hit and miss. The Razr i compass being bang on ... not sure I'd trust it mind, if my life depended on it
Not sure I can add a lot more. Early days of course but ask if you want to know anything. It's not 4g compatible but being on 3 doubt there will be anything doing in my area for some time anyway. Good 3g is fine for my use. The size suits me as always was a fan of the One S and this is similar though not quite as thin and so far no signal issues
So far so good
Plan was to use the Razr i and then sell it for maybe a Razr Maxx if and when it becomes available. Not sure I'm bothered now
