- 11 Dec 2005
- Cheshire
Neon ones innit!
what are you talking about?
Neon ones innit!
the saving could be kept for tyres, drugs and whores.
Completely in the wrong order!
... will do 35-37mpg at 70mph, less depending on the amount of traffic (slowing down and speeding up)ST220
aint one of them, can tell by the washer jets.
[TW]Fox;22900485 said:The Seat Leon is essentially a VW Golf with all the nice bits taken out, so you are left with a noisy, unrefined diesel hatchback filled with crap nasty plastics and cheap build quality. Add in the styling and it's probably my least favourite hatchback. Nasty things.
Personally I'd take a VW Jetta over a Leon every day of the week. It's fundamentally the same thing but without the horrid interior, nasty plastics and jellymould styling.
Edit: Eh!? You are looking at Mk1 Leons?! Thats the sort of car you buy with £2.5k not £5k. Step away from the Mk4 Golf platform vehicle. There is no need to buy that at this money, you can afford a car thats a generation newer!
Absolute twaddle![]()
The preface lift mk2 is absolutely horrendous as interiors go admittedly.
The facelift is basically the same as the current Golf / A3. From an interior point of view there is no argument.
Prefacelift mk2 Leon and the facelift are two different cars.
Does VAG have a special factory where they produce parts with the 'nice bits taken out' especially for Seat / Skoda or do they just reuse the same parts? Its the other way round. There are £50k Audis sharing the same parts as a Leon FR.
[TW]Fox;22907735 said:Which 50k Audi has the interior quality of a Leon?
disagree. Mine is 6 speed and does more like 33mpg at 70 indicated. Need to go less than 65mph to get anywhere near 37.
