Can anyone spec me a gaming rig for £300/£350
13 Jun 2012
UK, London
Can anyone spec me a system as well for the £300/350 price range?
ps i dont need memory, ssd/hdd or a monitor.
I wll be using it primarily for gaming (borderlands 2 etc)/browsing and streaming via the tv. At some point i wll probably attach my usb 3.0 external hd to the system.
Yes mate, what would you like. :D
Can you list the full spec of your present system?
Make and model of Psu. Do you need a case, OS, dvd or k&m?
The more components you can reuse, the more we can spend in other areas.
Im looking for a mobo, cpu, case and graphics card. A stock cooler for the cpu is fine or a cooler master pro rev 3.
My other systems is an i5, asus P8Z68-V PRO/GEN3, 650 ocz pw supply, evga gtx 560 ti etc.
Ive only used Asus mobos but am welcome to change if the functionality is there.
Having a silent/quiet running system is also desired.
I might be able to increase the limit to £400 to make things slightly easier.
If i was you, i would keep your i5(if it`s the 2500k) and mobo. Just get a Gpu, case and a cooler.
Or get a second hand 560ti, new IB Cpu, mobo, case and cooler.
To upgrade you would want the 3570k and a Z77 mobo at least. That will cost at least £270. That will only leave £130 for case and Gpu.
Ive got an old 600w power supply which I have cleaned, but it is still kinda noisey.
I would like a new one if it is possible to factor in..
Ok, done a little reshuffle
Included a "B" grade mobo and case. The mobo may have some accessories missing, but will still work. They both come with a 90 day warranty from OCUK and then after that, whatever manufacturers warranty is left.
The Psu is one of the best quality units around.
YOUR BASKET
1 x MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards w/ Nexuiz & Sleeping Dogs PC Games £155.99
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £99.95
1 x **B Grade** Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £60
1 x PC Power & Cooling Silencer Mk III Series 600W '80 Plus Bronze' Modular Power Supply - White £53.99
1 x **B Grade** Xigmatek Asgard Pro Gaming Case - Black £26.99
Total : £411.01 (includes shipping : £11.75).
