**OcUK FIRST AGAIN: LATEST VIEWSONIC VP2770-LED IN STOCK!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We've got in the latest Viewsonic VP2770-LED monitor which is potentially the best 27" IPS on the market, especially for response time. In our own testing in games we found the Viewsonic noticably was a more responsive panel for gaming on, whilst still maintaining all the benefits of a professional LED IPS based monitor.
OcUK is the only stockist and we've only got 10 units, which is the entire stock for the UK market, if you want the best, this is it:-
Viewsonic VP2770-LED 27" Widescreen Professional LED Monitor - Black @ £719.99 inc VAT
The 27” display VP2770-LED has a slim, uniform bezel design. It boasts an ultra-high 2560 x 1440 WQHD resolution and a 10 Bit panel which delivers 1.07 billion true colour for the ultimate quality in image and colour performance. The VP2770-LED reduces time on editing with the embedded Delta E=3 colour accuracy which renders the image colour, reproduced on display and print-out, as accurately as it is on camera.
The innovative SuperClear™ IPS wide-viewing angle technology provides a consistent and true-to-life image effect from any angle. In addition, the latest DisplayPort interface supports high definition image input and the built-in four USB hubs enable users to easily connect the display with peripherals. With an ergonomic design to offer users a comfortable work environment, the VP2770-LED creates bigger images and better impact.
VP2770-LED
SuperClear™ IPS (In-Plane Switching) reduces the amount of light scattering to offer 178-degree vertical and horizontal wide viewing angles. The displays also feature a short response time and accurate colour reproduction to provide premium viewing experiences on the monitor.
The VP2770-LED comes with a HDMI and DisplayPort digital interface to support the latest PC, high definition video and peripheral devices with just a transmission cable needed for instant plug and play.
The VP2770-LED features an adjustable monitor base, users are able to adjust the base from top to bottom with 28º of tilt, 90º of rotating pivot, 120º of horizontal swivel and a height adjust of up to 15cm. The multi-adjusting ergonomic design and 27-inch wide screen size effectively reduce fatigue
The VP2770-LED comes with a uniform slim bezel which is perfect for multiple monitor application. Matt bezel can avoid reflection which is ideal for the working environment. Users are able to adjust the base from top to bottom with 28º of tilt, 90º of rotating pivot, 120º of horizontal swivel and a height adjustment of up to 15cm. The multi-adjusting ergonomic design and 27-inch wide screen size effectively reduce fatigue.
Features:-
- WQHD 2560 x 1440 ultra high resolution
- SuperClear™ IPS technology
- Delta E<3 and 1.07 billion colours for colour accuracy and definition
- Flexible ergonomic design
- Versatile compatibility and connectivity
Specification:-
- Product Description: ViewSonic VP2770-LED - LED monitor - 27"
- Device Type: LED-backlit LCD monitor - 27"
- Built-in Devices: USB3.0 Hub
- Panel Type: IPS
- Aspect Ratio: Widescreen - 16:9
- Native Resolution: FullHD 2560 x 1440
- Brightness: 300 cd/m2
- Contrast Ratio: 1000:1 / 20000000:1 (dynamic)
- Response Time: 5 ms
- Input Connectors: HDMI, DVI-D, VGA, DisplayPort
- Display Position Adjustments: Height, pivot (rotation), swivel, tilt
- Screen Coating: Anti-glare, 3H Hard Coating
- Dimensions (WxDxH): 64.26 cm x 34.8 cm x 46.48 cm - with stand
- Weight: 8.5 kg
- Environmental Standards: ENERGY STAR Qualified
- Compliant Standards: FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, E-Standby, UkrSEPRO, KC, ERP
- Manufacturer Warranty: 3 years warranty
Only £719.99 inc VAT.
ORDER NOW
Just had our evaluation model sat on my desk for an hour.
brilliant warm colours, nice blacks and superb colour reproductions.
I initially felt that the image was nice but lacked warmth to the colours. the stock settings are very unforgiving but changing to the second preset really brings this panel into its own.
easily a contender against my Dell U3011
I especially like the quality of the stand, weighty and nicely built.
the panel itself has a nice anti glare on it which is more noticeable under our harsh office lighting.
The area this shines in is gaming. as a high end IPS panel user, it is surprising to see such quick response times from an IPS.
this is a great all rounder in my opinion and much better suited to a gamer than a Dell.
Yes it looks very nice.
But The price is so much more than a Hazro 27" i dont feel it would be worth it, Also all the response time market jibber jabber is moot when it is on par with the hazro
EDIT:
Ouch... 26.2Ms Input lag Vs a Hazro 4ms... hmmmm
I doubt most people would notice any difference between the input lag :)
But i agree it is overpriced compared to the others on the market:p
I was confused with this viewsonic screen since its been out for well over a year, even tftcentrals review was sep 2012, still remains a top quality screen.
The Samsung S27B970D 27" is @ 499.99 again for today on ocuk which looks cheaper and just as good.
Still according to toms hardware the Iiyama Prolite XB2779QS-S 27" or that Planar PXL2790MW maybe the 2 screens to look out for soon. Look forward to ocuk getting those Iiyamas in.
