AMD FM2 - DRIVING DOWN THE COST OF AFFORDABLE COMPUTING
11 Dec 2005
Cheshire
Today we introduce the "Primo 6300a" home system, designed with the all new AMD FM2 platform and A Series APUs. With seriously powerful onboard graphics and super quick clock speeds, the amount of performance on offer for the initial cost is crazy! For less than £300 with an Operating system (Windows 7 Home Premium), the "Primo 6300i" offers unbeatable performance.
"Primo 6300a" AMD A4-5300 3.40GHz DDR3 Dual Core APU System @ £299.99 inc VAT
The "Primo 6300a" offers the performance needed for home and business use at a low price. The AMD A4-5300 3.40GHz combined with 8GB of 1866MHz DDR3 RAM, offers a quick and easy multitasking experience.
Why You Should Buy This System?
- AMD A4-5300 3.40GHz (Socket FM2) offers multitasking performance.
- 8 Hours stressed tested and quality controlled
- 500GB hard drive gives a solid and reliable storage capacity.
- 8GB of 1866MHz DDR3 RAM allows for snappy and precise processes to be made.
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: OcUK IMP microATX case - Black
- Power Supply: OcUK Value 500W PSU
- CPU: AMD A4-5300 3.40GHz (Socket FM2)
- Motherboard: AMD A55 Chipset (Socket FM2) DDR3 Motherboard
- RAM: 8GB DDR3 1866MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: Integrated HD 7480D Graphics
- Sound: ALC662 6-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Compact, reliable and smart. The "Primo 6300a" give you everything you need in a entry level home/business system.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
*Buy any system from Overclockers UK with Windows 7 between now and January 31st 2013 and once launched, you can upgrade to Windows 8 for just £14.99! See full details here:http://www.overclockers.co.uk/LP/windows8_upgrade.php
Only £299.99 inc VAT.
ORDER NOW
Should really have 1866MHz mem in it though. Llano/Trinity is one of the few situations where faster mem is actually worth it.
