Well, there's plenty of benchmarks out there where the AMD CPU's are bottlenecking GPU's.
Plenty of information on these very forums.
Why get a GPU if you're going to limit it CPU wise? And it's not just a few FPS, even if the number difference isn't noticeable, why get the higher GPU to not use it to its full potential? It's illogical at best (Regardless of the platform)
I've used AMD systems before, I've built plenty, my 6870 Crossfire went faster when I moved from a 1090T @ 4.375GHZ to my 2500k.
Gareth had a 6970 Trifire pretty much and he too noticed improvements, even at stock clock on his 2500k as opposed his clocked FX8150.
I'm not saying AMD CPU's are unusable, but there's absolutely no reason on this Earth to get a GPU if you can't take it to its full potential, get a GPU that you can (While, not noticing the difference) and pocket the difference.
Those who want the 120 FPS, they're going to want the best, that is Intel for gaming, there's no question about it.
I'm hoping Vishera is capable of delivering that performance when clocked with a 7970, could make the 8 core a possible purchase.
