Regarding the reduced clocks, maybe they have found issues and have brought the top speed down a notch to protect our expensive purchases? Tis a bit gutting tho.![]()
BF3 is better for me in sli with these, high 70% to mid 80% usage now and seem to be holding the fps better than any others
It's what I had on my SLI 480 with my system @ 4Ghz. Just saw what you typed... Isn't that like pretty bad? 98/99 usage is much better right?It's what I had on my SLI 480 with my system @ 4Ghz.
If you have 70 - 80% doesn't that mean your system can't give your GTX's as much as they need?
Bf3 is badly optimised also, for both manufacturers.
.98-99% usage 6950>70 CrossFire, it was always good.
98-99% usage on 7970/7950 CrossFire with a [email protected], using the 12.9 betas, I can't comment on previous drivers though.
Please don't take this as a dig/slant at anyone/thing, simply being informative for the Nvidia Sli users..
Wow, ok didn't know even newer i5's were that crippled! Thanks for the information![]()
I'm using the 12.9's and I only get that usage in SP and Co-op or on a map with less than 20 players. Any more than that and utilisation craps itself. Are you running the cards at x8/x8 or x16/x16? Also what's your net speeds?
Long story short, I only had a brief affair with it for about a week, both on 8x8/1100MHz/16GB system ram/OS 128gbM4/BF3 running from 120GB Force 3, mostly on AK too@~10 meg.
It was complete overkill@1080p I may add.
When exactly are we talking about? now or from what you can remember? as I have heard last game patch screwed up SLI for lots of people, have you checked since last game patch?Just saw what you typed... Isn't that like pretty bad? 98/99 usage is much better right?It's what I had on my SLI 480 with my system @ 4Ghz.
It cannot be cpu bottle necking it, cpu usage is all ways around 70%, if it was a cpu problem as in bottle necked, I would expect it to be 100% used, it's not cpu, it's either DICE has messed up or Nvidia have still messed up, take your pick.
.A CPU bottleneck isn't as simple as that. On my i5 2500k I would see usage between 60-70% on all cores. On my i7 3770k I see the same kind of usage across all 8 threads and GPU usage moved from 80-85% to 95-99%.
It was the same install of Windows and drivers as well. I just took the old CPU out and plopped the new one right in.
Edit: the only thing I'm not sure on is the degree of bottleneck that will be there on SLI 4** series.
I don't believe for 1 minute it can be a cpu bottleneck with a 3570k clocked at 4.5ghz with 2 480, what are people using with sli 680's to not get a bottleneck? not all of them are running 3770ks I'm pretty sure of that, if anything most gamers never buy the HT version of a cpu.
. BF3 MP64 is quite heavily CPU bound actually for some reason. If they aren't running i7's they'll be ever so slightly bottlenecked. Well you don't have to believe it but it's true. BF3 MP64 is quite heavily CPU bound actually for some reason. If they aren't running i7's they'll be ever so slightly bottlenecked.
How else would you explain my jump in 10-15% in GPU usage on the same system? Gregster found the same thing when he moved to X79 although I believe his usage readings are a little more over the place.
An i5 is a nice chip, however if you want the utter max from your system and you play BF3 a lot then an i7 is better to get the max GPU usage. Some people are happy to take the 85% scaling with SLI as oppose to chugging more money on a CPU.
As I said, I am somewhat speaking from experience and I was perfectly happy with my set up with an i5 2500k @ 4.5 and SLI 680's. I then sold my CPU and motherboard and upgraded to Z77/Ivy for less than £100. The bump from i5 to i7 and PCI-E 2.0 and 3.0 was about 3-5% in BF3. Not worth it on its own but the reason was the releasing of the slight bottleneck and then minuscule bump from PCI-E 3.0.
Made me cautious to update but my boost clock remains untouched by this driver. Asus TOP 670 @ 1306mhzSame as the last lot according to release notes, but are on a new driver branch.
Some people have noticed reduced boost clocks. Boooo?
