3dMark score low?
28 Dec 2003
Just installed my new GTX 670 and did a quick 3dMark11 run, more to test all was ok than anything else.
On the standard Performance preset, got a score of 8096, which seems a bit on the low side compared to others with this card.
CPU is an i5-2500K, at stock frequencies - is it this that's holding the overall score back a bit? Just wondering if there's anything to worry about or whether I may have some settings that need tweaking at all is all :)
I guess I'll hi-jack this thread.
Just purchased a HD 7950. Running the latest drivers with an i5 760 @ 4.0GHz I got 6400, to me that seems low as my GTX 470 got 5400 at stock.
Graphics score?
I didn't note the individual scores I'm afraid, I'll re-run it tonight and do so :)
Can't be bothered clocking the i5 to be honest, it's more than fast enough at stock speeds really and no application or game is struggling in the slightest, I was just curious if there was some reason why my overall 3dMark score seemed a bit low.
The card itself is an EVGA GTX 670 FTW version btw, which is clocked slightly higher than standard 670 speeds but not massively so.
