FM2 ITX is coming....
20 Jul 2009
The bleak North East arm pit of Britain
Hello
As title really, the FM2 chipset is now coming to ITX from ASRock with others to follow.
Take a look below at this awesome little board :D
ASRock FM2A75M-ITX AMD A75 Chipset (Socket FM2) DDR3 Mini ITX Motherboard @ £73.99 inc VAT
The next generation “Trinity” A-Series APUs provide even more opportunity for tweaking and overclocking, and are better than ever at performing the compute-demanding activities (entertainment, gaming). Supporting AMD Radeon HD 7000 series graphics and DirectX 11 standards, the AMD next-gen A-Series APUs provide 3D gaming experiences similar to discrete-level graphics card solutions. The ASRock FM2 Platform takes advantage of AMD’s Trinity APUs, users can overclock the APU to gain further performance. With the powerful integrated graphics, the ASRock FM2 Motherboard Series can deliver 3DMark Vantage (Performance setting) scores of over 7200 points, providing up to 37.22% performance boost.
CPU
- Support for Socket FM2 100W processors
- Supports AMD's Cool 'n' Quiet Technology
- UMI-Link GEN2
Chipset
- AMD A75 FCH (Hudson-D3)
Memory
- Dual Channel DDR3 memory technology
- 2 x DDR3 DIMM slots
- Supports DDR3 2600+(OC)/2400(OC)/2133(OC)/1866/1600/1333/1066/800 non-ECC, un-buffered memory
- Max. capacity of system memory: 32GB*
- Supports Intel® Extreme Memory Profile (XMP) 1.3 / 1.2
- Supports AMD Memory Profile (AMP)
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
- 64Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- DRAM, VDDP, VDDR, SB Voltage Multi-adjustment
Audio, Video and Networking
Graphics
- AMD Radeon HD 7000 series graphics
- DirectX 11, Pixel Shader 5.0
- Max. shared memory 512MB
- Multi VGA Output options: D-Sub, DVI-D and HDMI
- Supports HDMI 1.4a Technology with max. resolution up to 1920x1200 @ 60Hz
- Supports Dual-link DVI with max. resolution up to 2560x1600 @ 75Hz
- Supports D-Sub with max. resolution up to 1920x1600 @ 60Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI (Compliant HDMI monitor is required)
- Supports Blu-ray Stereoscopic 3D with HDMI 1.4a
- Supports AMD Steady Video™ 2.0: New video post processing capability for automatic jutter reduction on home/online video
- Supports HDCP function with DVI and HDMI ports
- Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback with DVI and HDMI ports
Audio
- 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
- Premium Blu-ray audio support
- Supports THX TruStudio™
LAN
- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111E
- Supports Wake-On-LAN
- Supports LAN Cable Detection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE
Expansion / Connectivity
Slots
- 1 x PCI Express 2.0 x16 slots
Storage
- 4 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and "Hot Plug" functions
USB 3.0
- 2 x Rear USB 3.0 ports by AMD A75 FCH (Hudson-D3), support USB 1.1/2.0/3.0 up to 5Gb/s
- 4 x Rear USB 3.0 ports by Etron EJ188, support USB 1.1/2.0/3.0 up to 5Gb/s
- 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by AMD A75 FCH (Hudson-D3), supports USB 1.1/2.0/3.0 up to 5Gb/s
Connector
- 1 x IR header
- 1 x CIR header
- 1 x COM port header
- 1 x HDMI_SPDIF header
- 1 x Power LED header
- 2 x CPU Fan connectors (1 x 4-pin, 1 x 3-pin)
- 1 x Power Fan connector (4-pin)
- 24 pin ATX power connector
- 4 pin 12V power connector
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports)
- 1 x USB 3.0 header (supports 2 USB 3.0 ports)
- 1 x Dr. Debug with LED
- 1 x Power Switch with LED
- 1 x Reset Switch with LED
- 1 x Clear CMOS Switch with LED
Rear Panel I/O I/O Panel
- 1 x PS/2 Mouse/Keyboard Port
- 1 x D-Sub Port
- 1 x DVI-D Port
- 1 x HDMI Port
- 1 x Optical SPDIF Out Port
- 2 x Ready-to-Use USB 2.0 Ports
- 1 x eSATA3 Connector
- 6 x Ready-to-Use USB 3.0 Ports
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jack: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Other Features / Miscellaneous
Unique Feature
- ASRock Extreme Tuning Utility (AXTU)
- ASRock Instant Boot
- ASRock Instant Flash
- ASRock APP Charger
- ASRock XFast USB
- ASRock XFast LAN
- ASRock XFast RAM
- ASRock Crashless BIOS
- ASRock OMG (Online Management Guard)
- ASRock Internet Flash
- ASRock UEFI System Browser
- ASRock On/Off Play Technology
- ASRock Dehumidifier Function
- ASRock Easy RAID Installer
- ASRock Interactive UEFI
- Hybrid Booster:
- ASRock U-COP
Support CD
- Drivers, Utilities, AntiVirus Software (Trial Version), AMD Live! Explorer, AMD Fusion, CyberLink MediaEspresso 6.5 Trial, ASRock MAGIX Multimedia Suite - OEM
Accessories
- Quick Installation Guide, Support CD, I/O Shield
- 4 x SATA Data Cables
Only £73.99 inc VAT.
ORDER NOW
No mini Wi-fi card, damn shame.
I'd have pre-ordered one instantly if it had.
I realise the FM2 socket takes up a bit more room on an Itx board compared to intel.
Asrock should still have been able to shoehorn one on there, even if it was on the back of the board.
Let's hope someone else has the sense to put one on their boards, it's pretty much mandatory for ITX these days.
Not for me but kudo's to OcuK for trying to get their customers ITX FM2 boards.
I'm guessing from those nylon push pins that like Asrock Llano ITX boards this board doesn't come with a backplate for mounting CPU coolers (Can't even fit your own on the Llano board since there are components mounted on the under side). This will limit you to coolers that use spring clips.
Nope, no backplate supplied.
I cut down an AM3 steel backplate to fit a Noctua NH-C14 onto an Asrock FM2A7M-ITX board.
Runs great with an A10-5800K at a low volt 4.3ghz with 1085 on the gfx core.
DDR3 2133 ram with tight timings, this little board flies.
Enzotech Mosfets sinks I'd also recommemd if you plan to clock this board, with no active mosfet cooling out of the box, the mosfets get hot under load, very hot.
So, it is possible to mount any cooler really, sourcing metal AM3 backplates however is not (take note Andrew)
The readily available plastic AM3 backplates are not suitable to support a big cooler like the Noctua.
Top down coolers suit this board better to keep everything cool.
This cooler fits and does 'not' require a backplate at all.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-021-PL&groupid=701&catid=2330&subcat=2349
Noctua NH-L9a
http://www.noctua.at/main.php?show=productview&products_id=51&lng=en
and Thermalright's new AXP-100 are both due for imminent release in the UK.
For something more beastly it's a case of sourcing a backplate and trimming it to miss the IC's on the rear of the board.
