**WEEKEND ONLY DEALS ROUND 1: DELL MONITORS!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We shall be launching throughout today WEEKEND ONLY DEALS, which shall expire midday Monday, so grab yourself a bargain this weekend. Lets start the ball rolling with DELL monitors:-
Dell Ultrasharp U3011 30" Widescreen LCD Monitor - Midnight Grey @ £859.99 inc VAT
Experience amazing wide-angle viewing and color consistency with the DellTM UltraSharpTM U3011 30"W Monitor with PremierColor. Extensive connectivity features and customization via CustomColor mode make the U3011 an ideal choice for professionals in CAD/CAM, graphic design, gaming and other fields where color precision matters.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- 117% (CIE 1976) color gamut with excellent AdobeRGB and sRGB coverage for rich, lifelike visuals
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 100,000:1 Contrast Ratio
- 7ms Response Time (7ms Grey-TO-Grey)
- 370 cd/m2 Brightness
- Two DVI-D Input with HDCP support
- Two HDMI Input
- One Display Port Input
- One Analogue Input
- Component Connectors
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Was [£899.99] Inc. VAT
Only £859.99 inc VAT.
ORDER NOW
Dell UltraSharp U2713HM 27" Widescreen LED Monitor - Midnight Grey @ £529.99 inc VAT
Cinema-like clarity shines on the expansive 27" DellTM UltraSharp U2713HM monitor. Comfort settings and connectivity options help keep you productive. WQHD resolution and accurate colors out of the box: Superb clarity with 2560 x 1440 resolution and over 3.6 million pixels. Features a color gamut of more than 99-percent sRGB.
Excellent comfort and usability: Full adjustability including swivel, tilt, height adjustability and pivot which lets you easily switch to portrait mode. Eco-friendly design: Compliant with the latest environmental standards and made using environmentally conscious materials
2560x1440 WQHD resolution: Over 3.6 million pixels provide amazing clarity on a spacious 27" LED-backlit display. Easily adjust screen brightness to suit your environment. Accurate color right out of the box: Carefully color calibrated at the factory, the U2713HM monitor features more than 99-percent sRGB color space for impressive color from the moment you set it up. Wide-angle viewing: Uncompromised color consistency across an ultra-wide viewing angle of 178°/178° gives you broad viewing flexibility and lets you collaborate easily.
Full adjustability: Work comfortably and view images from a variety of positions with swivel and tilt. Easily switch to portrait mode with pivot. Set your U2713HM to the optimum height with a height-adjustability range of 115mm. Latest connectivity options: Seamlessly connect your monitor to your desktop, laptop and peripherals such as digital cameras and Blu-ray or DVD players. Digital and analog connections include four USB 3.0 ports, DisplayPort 1.2, DVI (HDCP) and HDMI. Stay productive with Dell Display Manager: This one-stop software tool lets you quickly access applications such as Auto Mode, Easy Arrange and PowerNap. Use Auto Mode to adjust or auto-assign preset modes to specific applications. Use Easy Arrange to neatly tile your applications, arranging them in your preferred layout
Meets latest environmental standards: The U2713HM monitor meets EPEAT® Gold and TCO Certified Displays standards, is ENERGY STAR® qualified and CECP compliant. Made with responsible materials: This monitor is made with arsenic-free glass, a mercury-free panel, uses 25-percent post-consumer recycled plastics in its chassis and BFR/PVC-free laminates in its circuit boards. The U2713HM also ships with environmentally responsible packaging. Helps save resources: Enable PowerNap mode to reduce power consumption by dimming the monitor to minimum brightness or by putting it into sleep mode.
Features:-
- LED Backlit
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 2,000,000:1
- Brightness: 350cd/m²
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI, 1x DisplayPort,
- 5-Port USB3.0 Hub
- VESA Compliant
- Dimensions: 639.3mm (25.17'') x 200.3mm (7.89'') x 424.3mm ~ 538.9mm (21.22'' ~ 16.70'')
- Weight: 10.20kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Was [£599.99] Inc. VAT
Only £529.99 inc VAT.
ORDER NOW
Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey @ £519.95 inc VAT
With its amazing colour accuracy and versatile connectivity, the high-performance Dell U2711 Monitor delivers stunning detail, depth and responsiveness. PremierColour technology allows the Dell U2711 Monitor to deliver reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. Factory-tuned Adobe RGB and sRGB modes minimize the need for further colour calibration; each monitor arrives with a certified colour-calibration factory report. 100% sRGB and 96% AdobeRGB meets the needs of professional users involved in colour-centric work such as graphic design, CAD/CAM, gaming and media creation.Customize your viewing experience with the height-adjustable stand and tilt/swivel features - or save valuable desktop space by detaching the panel from the stand for wall mounting.
- Height Adjustable
- Contrast Ratio: 80000:1
- Response Time: 6ms
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 2x DVI-D, 1x HDMI, 1x DisplayPort, 1x Composite & 1x Component
- 4-Port USB Hub
- 8-in-1 Card Reader
- VESA Compliant
- Dimensions: 646.71mm x 427.83mm x 199.95mm
- Weight: 7.72kg
Was [£539.99] Inc. VAT
Only £519.95 inc VAT.
ORDER NOW
Dell Studio S2740L 27" Widescreen LED Monitor - Black @ £289.99 inc VAT
These new S-line models are being marketed as "virtually frameless" although there is of course still a bezel on the monitor. Some of the models (27" and 24") will also feature "edge-to-edge" glass designs and so will offer glossy panel coatings which many users prefer to the often grainy AG coatings usually on offer.
Get a front-row seat with the sophisticated S2740L 27" monitor, featuring ultra-wide viewing, edge-to-edge glass and our Image Enhance feature.
Features:-
- Sophisticated styling: Experience a lifelike view with a virtually frameless 27" screen featuring edge-to-edge glass.
- Superb performance: Images come alive with color-boosting Image Enhance, ultra-wide viewing and Full HD resolution (1920 x 1080 max.) in a 16:9 widescreen format.
- Versatile connections: Connect to a laptop or desktop with VGA and DVI-D (HDCP). Explore HD viewing options with HDMI. Connect to devices with two USB ports.
- Virtually frameless: An edge-to-edge glass design creates an expansive view.
- Big and bold: Images appear lifelike on this glossy, LED-backlit 27" monitor.
- Beauty plus refinement: Add elegance and contemporary style to your media room or home office. The S2740L monitor offers a pristine finish, premier craftsmanship and a streamlined cable design.
- Ultra-wide viewing angle: Get immersed from nearly any perspective with an ultra-wide 178°/178° viewing angle.
- Stunning clarity: Savor razor-sharp detail in games, movies and photos with color-boosting Image Enhance. Vivid clarity shines with a mega-dynamic contrast ratio of 8 million:1 (typical) and an 84-percent color gamut1.
- Customizable color: Dell Display Manager helps keep you productive with fast access to software such as Auto Mode, which enables you to select your preferred color mode for each application.
- Full HD resolution: Watch images come alive in cinematic quality with Full HD resolution (1920 x 1080 max.) in a 16:9 widescreen format.
- Be comfortable: Set your preferred viewing angle with extensive tilt adjustability. Tilt the S2740L panel up to 4° forward or 21° backward.
- Stay versatile: Connect to your laptop or desktop with VGA and DVI-D (HDCP). The HDMI port lets you explore high-velocity HD entertainment options. Connect to multiple devices with two USB ports.
- Organize your screen: Tile your applications with Easy Arrange software so you can see them all clearly at a single glance. Even select your preferred desktop design layout.
Specification:-
- Panel Technology: IPS
- LED Backlit
- Resolution: 1920x1080
- Contrast Ratio: 8,000,000:1
- Brightness: 270cd/m²
- Response Time: 7ms
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI.
- 2-Port USB3.0 Hub
- VESA Compliant (100x100mm)
- Dimensions: Height: 458.7 mm (18.06 inches), Width: 641.9 mm (25.27 inches), Depth: 215.8 mm (8.50 inches)
- Weight: 8.20kg
Was [£299.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
Dell UltraSharp U2410 24" Widescreen LCD Monitor - Midnight Grey @ £349.99 inc VAT
Experience astounding colour accuracy, precision and performance with the Dell UltraSharp U2410 Monitor. The U2410 is packed with features that make it easy to connect and a pleasure to use, no matter how much screen time you log including Picture-in-Picture, adjustable stand, touch controls and extensive connectivity. Thanks to PremierColor technology, the U2410 Monitor delivers reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. A colour gamut of 110% delivers vibrant, true-to life colour across all display modes.
- Screen Size: 24" IPS Widescreen
- Resolution: 1920x1200
- Brightness: 400cd/m²
- Inputs: 1x Component, 1x Composite, 1x VGA, 1x DisplayPort, 2x DVI-D & 1x HDMI
- Adjustable Stand
- VESA Compliant
- Dimensions: 559.7mm x 493.0mm x 201.5mm
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Was [£359.99] Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
Dell UltraSharp U2412M 24" Widescreen LED Monitor - Midnight Grey @ £215.99 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style. Powerful:
- Experience IPS technology, featuring a wide viewing angle with high-quality color representation for a peerless viewing experience.
- Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
- Customizable: Change your energy usage settings, text brightness and color temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel.
Whether for work or for play, the Dell UltraSharpTM U2412M can deliver an unmatched viewing experience.
- Clearly outstanding: Watch your graphics come to life on a vast 24" (61cm) LED-backlit screen featuring a crystal-clear 1920x1200 resolution on a 16:10 widescreen aspect ratio so you can’t lose screen area just because your customized applications support a different resolution.
- Contrasting view: Get ready for blur-free viewing with 2 million:1 (typical) high dynamic contrast ratio and 8ms with overdrive gray-to-gray (typical) response time that helps ensure crisp, sharp and ghost-free images.
- Colorful character: Enjoy an amazing range of rich, dramatic and accurate colors, thanks to IPS technology designed to give you color consistency across a broad viewing angle and a wide color gamut at 82% (typical).
- Premium Panel Guarantee: 100% replacement of Dell UltraSharp series monitors sold if any bright pixel is found, valid within the warranty1 period.
Specification:-
- 24" (60.96 cm) viewable area
- Widescreen (16:10)
- Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
- 1920 x 1200 at 60 Hz
- 1000 : 1 (typical)
- 2,000,000:1 (dynamic)
- 300 cd/m2 (typical)
- 8ms (gray to gray) Typical
- 178º / 178º
- 16.7 million colors
- Color Gamut: 82% (CIE 1976)
- 0.27 mm
- 1x Digital Visual Interface connectors (DVI-D) with HDCP
- 1x DisplayPort(DP)
- 1x Video Graphics Array (VGA)
- 1x USB 2.0 upstream port
- 4x USB 2.0 downstream ports
- DC power connector for Dell Soundbar
- Height-adjustable stand, tilt , swivel , pivot and built in cable-management
- Flat Panel Mount Interface
- VESA Mount
Was [£229.99] Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Dell Studio S2440L 24" Widescreen LED Monitor - Black @ £184.99 inc VAT
Dive into brilliance with the distinctive S2440L 24" monitor, featuring ultra-wide viewing, edge-to-edge glass and our Image Enhance feature. Images come alive with colour-boosting Image Enhance, ultra-wide viewing and Full HD resolution (1920 x 1080 max.) in a 16:9 widescreen format. Connect to a laptop or desktop with VGA connectivity. Explore a world of HD entertainment options with an HDMI port.
Features:-
- Contemporary styling: Always enjoy a magnificent view with a virtually frameless 24" display featuring edge-to-edge glass.
- Versatile connections: Connect to a laptop or desktop with VGA connectivity. Explore a world of HD entertainment options with an HDMI port.
- Virtually frameless: An edge-to-edge glass design creates a magnificent view.
- Big and bold: Images appear true-to-life on this glossy, LED-backlit 24" monitor.
- Beauty and refinement: Add elegance and style to your living room or home office. The S2440L monitor offers a pristine finish, premier craftsmanship and a streamlined cable design.
- Ultra-wide viewing angle: The stellar view pulls you in from nearly any perspective with an ultra-wide 178°/178° viewing angle.
- Stunning clarity: Savor razor-sharp detail in games, movies and photos with color-boosting Image Enhance. Vivid clarity shines with a mega-dynamic contrast ratio of 8 million:1 (typical) and an 89-percent color gamut1.
- Be comfortable: Set your preferred viewing angle with extensive tilt adjustability. Tilt the S2440L panel up to 4° forward or 21° backward.
- Stay versatile: Connect to your laptop or desktop with VGA connectivity. The HDMI port enables you to explore thrilling HD entertainment options.
Specification:-
- Panel Technology: VA
- LED Backlit
- Screen Size: 24" VA Widescreen
- Brightness: 250cd/m²
- Inputs: 1x Analogue, 1x HDMI
- Dimensions: Height: 417.9 mm (16.45 inches), Width: 567.4 mm (22.34 inches), Depth: 190.8 mm (7.51 inches)
- Weight: 4.95kg
- Product Review: http://www.tftcentral.co.uk/reviews/dell_s2440l.htm
Was [£199.99] Inc. VAT
Only £184.99 inc VAT.
ORDER NOW
Dell Studio S2340L 23" IPS Widescreen LED Monitor - Black @ £149.99 inc VAT
Be a part of the action. The elegant S2340L 23" monitor offers ultra-wide viewing, a virtually borderless screen and our Image Enhance feature.
Features:-
- Contemporary styling: Experience a lifelike view with an elegant, virtually borderless 23" display featuring an almost-invisible bezel.
- Virtually borderless: Creative projects, movies and games appear expansive on this 23" screen with an almost-invisible bezel.
- Pure elegance: Add refinement to your studio or home office. The S2340L monitor offers a pristine finish, premier craftsmanship and a streamlined cable design.
- Stunning clarity: Savor razor-sharp detail in games, movies and photos with color-boosting Image Enhance. Vivid clarity shines with a mega-dynamic contrast ratio of 8 million:1 (typical) and an 82-percent color gamut1.
- Full HD resolution: Images come alive with Full HD resolution (1920 x 1080 max.) on this glossy 23" screen in a 16:9 widescreen format.
Specification:-
- LED Backlit
- Screen Size: 23" IPS Widescreen
- Dimensions: Height: 398.9 mm (15.70 inches), Width: 532.2 mm (20.95 inches), Depth: 175.8 mm (6.92 inches)
- Weight: 3.95kg
Was [£169.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Dell Studio S2240L 22" IPS Widescreen LED Monitor - Black @ £134.99 inc VAT
Jump in the action with the modern S2240L 54.6 cm (21.5") monitor, offering ultrawide viewing, a virtually borderless screen and our Image Enhance feature.
Features:-
- Virtually borderless: Creative projects, movies and games appear expansive on this 21.5" screen with an almost-invisible bezel.
- Ultrawide viewing angle: The stellar view pulls you in from nearly any perspective with an ultrawide 178°/178° viewing angle.
- Distinctive styling: Add refinement to your studio or home office. The S2240L monitor offers a pristine finish, premier craftsmanship and a streamlined cable design.
- Stunning clarity: Savor razor-sharp detail in games, movies and photos with the color-boosting Image Enhance feature. Vivid clarity shines with a megadynamic contrast ratio of 8 million:1 (typical) and an 82 percent color gamut1.
- Customizable color: Dell™ Display Manager helps keep you productive with fast access to software such as Auto Mode, which enables you to select your preferred color mode for each application.
- Full HD resolution: Images come alive with Full HD (high-definition) resolution (1920x1080 max.) on this glossy 21.5" screen in a 16:9 widescreen format.
- Be comfortable: Set your preferred viewing angle with extensive tilt adjustability. Tilt the S2240L panel up to 4° forward or 21° backward.
- Stay versatile: Easily connect to your laptop or desktop with VGA connectivity. The HDMI™ port enables you to explore thrilling HD (high-definition) entertainment options.
- Be environmentally responsible: In addition to being ENERGY STAR®- qualified and EPEAT® Silver-registered, the S2240L monitor features arsenic-free glass and a mercury-free LED panel.
- Save resources: Reduce power consumption by dimming the monitor or by putting it into sleep mode by enabling PowerNap.
- Gain support: The S2240L monitor comes with Dell’s Limited Hardware Warranty2 and Advanced Exchange Service.
Specification:-
- LED Backlit
- Dimensions: Height: 380.2 mm (14.97 inches), Width: 499.1 mm (19.65 inches), Depth: 175.8 mm (6.92 inches)
- Weight: 3.69kg
Was [£149.99] Inc. VAT
Only £134.99 inc VAT.
ORDER NOW
DELL monitors have un-questionable quality and at these pricing are bargains! :D :D :D
Argh stop tempting me to pick up another u2412m. Its just a shame about the postage costs.
thanks gibbo
Wanted to know before i placed my order today didnt want to miss out.
Trying one for the time being as want to see what its like before buying another 2 for multi monitor use.
thanks gibbo
In short best 27" I've used! :)
I knew it.. I wait 2 weeks to buy a monitor then buy one and then these deals come up lol :D
Bloody typical.
Seriously? I just paid £149.99 for the Dell S2240L from OcUK on Thursday!
Gibbo can you do anything for me? Pretty please :)
Order number OC1494911
