**WEEKEND ONLY DEAL ROUND 4: A ZOTAC MINI-PC AT A TRULY CRAZY PRICE!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK this little Mini-PC is a superb piece of kit, the price is truly mental, check this out:-
Zotac Z-Box SD-ID12 Intel Atom Mini PC @ £119.99 inc VAT
Introducing the ZOTAC mini-PC series – the perfect everywhere mini-PC for all your computing needs. Whether it’s your living room, kitchen, bedroom or office, the ZOTAC mini-PC series are perfect for all your needs and demands thanks to the miniature size and versatile placement options.
ZOTAC mini-PC series are powered by high-performance yet energy-efficient CPUs and GPUs that delivery plenty of computing power while consuming minimal amounts of energy for eco-friendly computing. The ZOTAC mini-PC series pack plenty of power and performance for your routine tasks such as web browsing, checking e-mail, word processing, video playback and other tasks.
Take the first step to living green with the eco-friendly and energy-efficient ZOTAC ZBOX SD-ID12 mini-PC powered by Intel® Atom™ technology combined with Intel® Graphics Media Accelerator 3150 graphics. The ZOTAC ZBOX SD-ID12 mini-PC delivers phenomenal performance and compatibility for a full Microsoft® Windows® 7 experience with Aero® user interface while maintaining best-in-class energy-efficiency.
The ZOTAC ZBOX SD-ID12 mini-PC is easy to master with only two thumb screws in place to unlock the internal expansion capabilities. Inside the ZOTAC ZBOX SD-ID12 mini-PC is space for a 2.5-inch SATA hard drive and 204-pin DDR3 DIMM module while USB 2.0, eSATA and a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) provide external expansion.
Features:-
- Intel® HyperThreading technology
- Intel® ClearVideo (SD) technology
- Microsoft® DirectX® 9 compatible
- OpenGL® 1.5 compatible
- Energy-efficient computing
Specifications:-
- Intel® Atom™ D525 CPU (1.8 GHz, dual-core)
- Intel® NM10 Express chipset
- Intel® Graphics Media Accelerator 3150 GPU
Internal Expansion:-
- 1x 2.5-inch SATA 3.0 Gb/s hard drive
- 2x 204-pin DDR3-800 SO-DIMM
Display Outputs:-
- HDMI (720p)
- HDCP compliant
- VGA
Front Ports:-
- Headphone/Audio out jack
- Microphone jack
- 6-in-1 Memory card reader (MMC/SD/SDHC/MS/MS Pro/xD)
- 1 USB 2.0 port
- WiFi LED
- Hard drive LED
- Power button
- Dimensions: Length: 7.40in - 188mm, Width: 7.40in - 188mm, Depth: 1.73in - 44mm
Rear Ports:-
- 1x eSATA
- 4x USB 2.0 ports
- 10/100/1000 Ethernet (RJ45)
- Digital S/PDIF output
- Power connector
Top Ports:-
- 1x USB 2.0 port
Inside the box:-
- ZOTAC ZBOX SD-ID12
- Power brick & cable
- VESA monitor mount (w/4 screws)
- Stand
- Warranty: 2yr
Was [£139.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
This is a crazy deal, remember this little PC can be attached to the rear of a VESA compliant monitor or makes an excellent little streaming box for movies. Such a great bargain, don't miss out! :D :D :D :D
Mmmmmm very nice.
That might just be perfect for what my mother needs, a new PC. It's quite a smart little thing, could easily mistake it for a router!
Will it run MAME/other emulators smoothly? Also, am I being stupid? I can't find where it says how much RAM it has?
There's no RAM or hard disk included Narj, which explains the very low price.
Ideal for you to spec up something either pretty nippy with SSD, or keep the cost low and put in a ~250Gb 2.5in HDD knowing it'll barely get 1/10th used in its' life.
