Was just looking over their review:
http://www.vortez.net/articles_pages/thermalright_silver_arrow_sb_e_extreme_review,8.html
Couple things jump out. H100 shows 4.6-6.7c cooler stock and 12-12.6c cooler overclocked than K2 and D14.
How can this be when other reviews show D14, K2, and Phanteks all within a couple of degrees of H100.
Test system, coolers compared and methodology:
But when I searched Vortez reviews I found D14 in 500r, but can't find reviews of other coolers SA SB-E Extreme is compared with in this review.
CPU - Intel Core i7-3930K (3.6GHz)
Motherboard - GIGABYTE X79-UP4
Memory - 8GB Corsair Vengeance LP 1600MHz CL9
Graphics – Sapphire Radeon HD 6850 1GB
PSU - NZXT Hale90 650W
Hard Drive - Kingston HyperX 240GB SATA III SSD
Case - Corsair Carbide 500R White
Program Suite
Real Temp – Maximum temperature analysis
LinX 0.6.4 – Applies thorough stress test to CPU
CPU-Z – Confirmation of CPU frequency/voltage
AIDA64 Extreme Edition – Confirmation of temperatures/fan speeds
CPU Coolers
Alpenföhn Matterhorn Pure(120mm Wingboost: 300-1200RPM)
Alpenföhn K2 (120mm Wingboost: 500-1500RPM, 140mm Wingboost: 300-1100RPM)
Alpenföhn Gotthard (140mm Wingboost: 300-1100RPM)
Noctua NH-D14 (120mm NF-P12 PWM + 140mm NF-P14 PWM: up to 1200RPM)
Thermalright SilverArrow SB-E Extreme (Dual TY-143 fans – 600-2500RPM)
Corsair Hydro H100 (Dual 120mm fans – low: 1300RPM, mid: 2000RPM, high: 2600RPM)
Testing methodology
Testing will be based on temperatures recorded by Real Temp after 20 passes of LinX stress test. The maximum absolute temperatures will be recorded after the test and averaged over the 6 cores. The delta is then calculated by subtracting the ambient temperature recorded near the intake fans from the average temperature calculated. Tests are conducted with the Intel i7 3930K at its default 3.6GHz stock speed and overclocked to 4.6GHz @ 1.42V. The tests are done inside the Corsair Carbide 500R chassis to simulate real world conditions. To keep the tests standardised we are using Noctua's NT-H1 thermal paste on all coolers.
CPU coolers are reviewed as they come out of the box – with their factory cooling fans, as the manufacturer intended and as the consumer expects.
Additional tests include a passive test where the cooling fans are taken away from the heatsink and a comparison between the cooler used with stock thermal paste against our Noctua NT-H1 paste.
I know I have TY-143 fans on my Phanteks.
H100 with all Gentle Typoons must be pretty nice, but can probably buy two normal air coolers for that much money invested.
