The perfect screwdriver...
15 Jul 2012
I've been searching my whole life for the perfect screwdriver. Ok, maybe not my whole life but past couple of years I've really wanted to find a great screwdriver for pc building.
I would like it to have:
  • A removable long shaft (har har)
  • The right sized screwdriver bit and be high quality.
  • Prefer it to be already magnetized.
  • Not sure if it should be a ratchet style one or not, but would be handy to have the option.
Have a grip that:
  • Is lightweight so you can have better control over it.
  • Won't give your hand blisters after doing a full build.
  • None of that rubbery spikey stuff on the grip.
  • Grip should be narrow enough for cramped motherboard installations or have long enough shaft.
I would have more luck if I knew what size the correct Phillips head is for standard PC screws. Might seem a bit OTT but I'm fed up of not having the right tools. :)
No competitor links. Thank you.
I use this kit in work, there is a regular ratchet screwdriver handle, A couple of extended manual handles with sockets for bits and bits include: flat, philips, torx, sec torx etc I have yet to find a pc job that they cant handle.
Apologies, I wouldnt have thought they were in direct competition though.
http://***********/
You might want to remove that link as they sell some of the same stuff that OCUK sell so they are a competitor
best screwdriver ive every purchased was from the pound shop about 8 years ago still using it today
Not sure this fits all your requirements and not cheap but the best screwdriver I have ever owned!
http://www.ebay.co.uk/itm/WERA-KK-6...530&pid=100015&prg=1006&rk=1&sd=230859218646&
That driver is an absolute beast lol, tempting XD. The handle looks a bit wide to me, sometimes I have very limited space to work with. I guess I should worry less about the handle and get one of those wriggly extension thingies for awkward places. Going to see what else this WERA company sells. :)
Wera Kraftform Kompakt 41 Rapidaptor Set - 11pc that seems more in my price range. :p £25
YOUR BASKET
1 x 34 Piece PC Tool Kit £19.98
Total : £25.96 (includes shipping : £4.98).
Yeah I hate that kind of handle! Gives me a whole hand blister!
I think I know which shop he means lol. I was in there lookin at their screwdrivers the other day, had 1 good set but it was all precision pieces so useless really.
I don't see how they can be called a competitor, their prices are 2-3x what overclockers ask for. Still, they don't deserve to be mentioned, clueless staff and ripoff prices. :p - Friendly, gormless though.
I've found some more "comprehensive" PC/networking toolkit's. I want to go to Uni next year so I guess it won't hurt to get a good toolkit now. :)
I wasn't suggesting you buy that set from OCUK I was just showing 'PapaLazaru' that OCUK do indeed sell screwdrivers.
What you actually need is a plain phillips number 1 screwdriver, there is certainly no need to be spending £51 odd for one.
I have a series of Phillips screwdriver bits here numbered from 00 to 3. Size 1 is the best fit of the series.
I'd suggest that the "perfect screwdriver" is whichever one is closest to hand and fits the screw.
It's okay, I know you were. :) Also thank you I'll have a look at plain ones!
http://www.wickes.co.uk/precision-reversible-screwdriver-set-pk8/invt/167315/?source=123_74
I have these seems to fit the bill perfest and a you can magnatize them your self.
Thank you that look's like what I want! I will magnetize myself (the screwdriver bits), I lost my magnet though. :p
Blisters from building computers? Seriously, you trying to snap the screws off or something? :p
Haha, maybe a bit heavy handed. I try to be gentle. :$
