What is everyone running for Pll overvoltage?
I have been having some odd experiences with this voltage.
Default is 1.7? Well if i leave over voltage disabled it defaults to 1.7 on my board.
Windows will not boot with it disabled. I enable it and it remains at 1.7 unless i change it manually. Once enabled windows will boot despite it being the exact same voltage as when disabled.
Once its enabled i have been able to lower it to 1.5v so far without any changes in stability. Windows still boots fine so long as in bios it shows as enabled @1.5v.
My 2500k is @4.7ghz. With 4.6ghz i can leave it disabled and at default voltage of 1.7 fine, however going up to 4.7ghz requires it to be enabled as i mentioned above or windows hangs on boot every time.
) Thanks for this
