Halloween costume good for "famous movie characters" stag do as well
18 Oct 2002
Hi there,
I've got a couple of separate Halloween parties to go to soon, as well as a stag do early next year where the theme is famous movie characters. I figured that instead of spending a little bit of each one and having a half arsed costume I could spend £100 or so on a really good costume and use it for all three.
I've thought about doing Beetlejuice, Edward Scissorhands and Pennywise The Clown (from IT); but does anybody have any other suggestions as I'm not massively keen on those? I'm hoping there's some sort of Professor Badass character i've missed
B@
I'm not sure of your build, so it would vary based on that, but if you're pretty tall and stocky, you could go for a Leatherface/Jason style character? General scary beast.
Freddy Krueger would be fairly easy to do, provided you're OK with a mask... or disfiguring yourself.
Ironman FTW
