That depends on what you define as small ? the early Agiea PhysX games are still supported:
[/url]
Physx is the only selling point Nvidia have, and so it gets ratcheted up as tho it's the only thing that maters, it's not, it's just all they have.
It's like me banging on about advanced,- AA, Lighting and a few other glossy eye candy effects AMD now have which run about as well on Nvidia cards as Physx runs on the CPU, i would not have thought Physx is difficult to replicate so we may well see that added to the Gaming Evolved list.
Then what? what do Nvidia have then to keep the prices so high?
I began playing borderlands 2 on my 6950 with physx on low, then I upgraded to a 670 and banged physx onto high. I cant say theres a massive difference either way and tbh theres parts of the game where the physx has caused me some pretty significant slowdown so my physx setting is now on medium because of it.
its not the only selling feature nvidia have. more stable drivers, not needing to wait until it gets a huge boost a month later etc.
but im not going to start a circular argument here so lets leave it as, choices are good to have, they are all valid.
Nvidia's Drivers are no more stable than AMD's, so don't give me that.
Don't say you don't want to start a circular argument, and then start a circular argument.
A few months after release AMD and Nvidia drivers are usually equal. I would have to say though that from experience, while both companies mess up, I would have to give nvidia the edge for stability with early driver releases. At this point in the current generation though the difference between the two is negligible
But when talking about this kind of topic you can't just take the here and now, you have to consider everything.
you can quote that from both sides, they have all had problems in the past and they will all have problems in the future.
What's the point? it's already going round in circles with you and me, there is no win in that argument, just mindless rhetoric.
