ABSOLUTLEY BERSERK AMD FM2 OC BUNDLE!!!
11 Dec 2005
Cheshire
Check those clock speeds :p A lovely 4.40GHz on the APU, extra 200MHz overclock on the onboard graphics and a whopping 2133MHz on the memory.
Radon TURBO AMD A10-5800K 3.80GHz @ 4.40GHz DDR3 2133MHz Overclocked Bundle @ £299.99 inc VAT
Designed by experts the "Radon TURBO Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Radon TURBO Bundle" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 8GB of Dual Channel DDR3 memory overclocked to 2133MHz delivers unlimited bandwidth
- Advanced APU graphics overclocked to 1000MHz!!
Bundle Specification
- CPU: AMD A10-5800K 3.80GHz @ 4.40GHz Quad Core APU
- Motherboard: Gigabyte F2A85X-UP4 (Socket FM2) DDR3 Motherboard
- RAM: Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-15000C11 1866MHz @ 2133MHz Dual Channel
- Cooler: Zero Infinity Shiva CPU Cooler - Black
- GPU: Onboard AMD HD 7660D 800MHz @ 1000Mhz Graphics
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £299.99 inc VAT.
ORDER NOW
Its kinda crazy considering you can combine this with just a PSU and case to get a decent budget gaming machine for about 500 quid. And that's all with quality top brand components.
Hooray, an offer without using the word "CRAZY" in the title, someone must have the thesaurus out :p :D
Anyone run any benchies on this system yet?
Definitely, FM2 really has re-created the cheap gaming system. I can't get over how good the onboard graphics.
Not sure I understand how this works either. Is the GPU in the actual CPU or is it part of the Mobo? Can you still put a 'normal' cpu and dedicated graphics card in here at a later date?
how would this compare with an overclocked i5 bundle in both terms of gaming with onboard graphics and also just general computing performance. cpu, memory and motherboard effeciency between the two?
what dedicated graphics card could be compared to the amd on board one please?
I'm trying to way up what setup to build for my daughter and sons computer for xmas so any suggestions and advice re this new technology would be most appreciated. Thank you. :)
its part of the CPU.
The CPU and GPU are integrated into one unit. The GPU's on these AMD chips are actually pretty impressive for what they are.
So, you can you still replace this with a 'normal' cpu and dedicated graphics card at a later date? Or does this mobo always require this dual-cpu/gpu chip?
I'm interested in this for just the same reasons pls...
Well FM2 is AMDs current GEN APU socket so will probably only ever fit CPUs that have the onboard graphics as that is what the socket is designed for.
from what i have read cpu wise it still lags a touch behind the i3. i think i am going to go with the i5 myself and make do with onboard graphics. if needed i can upgrade this at a later date with a dedicated card.
However as my daughter will only be approaching 8 around xmas time i dont envisage she is going to be playing some of today's blockbuster, hence, my decision.
