NEW RANGE OF SPECTRE COLOUR SCHEME OC BUNDLES!!!!
11 Dec 2005
Cheshire
Introducing our new range of "Spectre" overclocked bundles, with fantastic colour schemes designed for the fashion savvy amongst the PC modding community. Featuring the Intel Z77 chipset and both Intel Core i5 & i7 CPUs for truly epic performance.
"Spectre Z77 Lava" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Overclocked Bundle - Quad Core @ £661.99 inc VAT
Showcase your style with our new range of "Spectre" Overclocked bundles. With a unique colour scheme designed by experts the "Spectre Z77 Lava OC Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Spectre Z77 Lava OC Bundle" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 8GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
Bundle Specification
- CPU: Intel Core i5 3570K 3.40GHz @ 4.40GHz Ivybridge CPU
- Motherboard: Gigabyte Z77X-UP7 Intel Z77 (Socket 1155) DDR3 Motherboard
- RAM: GeIL Enhance Corsa 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Cooler: Prolimatech Megahalems Black CPU Cooler - w/ x2 Xigmatek Orange 120mm LED Fan
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £661.99 inc VAT.
ORDER NOW
"Spectre Z77 Aqua" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Overclocked Bundle - Quad Core @ £431.99 inc VAT
Showcase your style with our new range of "Spectre" Overclocked bundles. With a unique colour scheme designed by experts the "Spectre Z77 Aqua OC Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Spectre Z77 Aqua OC Bundle" will accelerate your computer experience into the next level.
- Motherboard: MSI Z77A-G45 Intel Z77 (Socket 1155) DDR3 Motherboard
- RAM: Corsair Vengeance Artic White 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Cooler: Phanteks PH-TC14PE CPU Cooler - Blue
Service Package
Only £431.99 inc VAT.
ORDER NOW
"Spectre Z77 Emerald" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Overclocked Bundle - Quad Core @ £446.99 inc VAT
Showcase your style with our new range of "Spectre" Overclocked bundles. With a unique colour scheme designed by experts the "Spectre Z77 Emerald OC Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Spectre Z77 Emerald OC Bundle" will accelerate your computer experience into the next level.
- Motherboard: Gigabyte Sniper M3 Intel Z77 (Socket 1155) DDR3 Motherboard
- RAM: Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Cooler: Prolimatech Megahalems Black CPU Cooler - w/ x2 BitFenix Pro 120mm Green LED fans
Service Package
Only £446.99 inc VAT.
ORDER NOW
"Spectre Z77 Ruby" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDr3 OVerclocked Bundle - Quad Core @ £456.98 inc VAT
Showcase your style with our new range of "Spectre" Overclocked bundles. With a unique colour scheme designed by experts the "Spectre Z77 Ruby OC Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Spectre Z77 Ruby OC Bundle" will accelerate your computer experience into the next level.
- Motherboard: Asrock Z77 Extreme 4 Intel Z77 (Socket 1155) DDR3 Motherboard
- RAM: Geil Veloce Hot Rod 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit
- Cooler: Prolimatech Genesis Black CPU Cooler - w/ x2 BitFenix Pro 120mm Red LED fans
Service Package
Only £456.98 inc VAT.
ORDER NOW
"Spectre Z77 Emerald" is pretty much what i am running now but with 16gb of the tracer ram.
excellent performance and the board is frankly superb. one of the best motherboards i have owned in years.
native intel controllers for everything, brilliant.
Emerald looks awesome. But I think you should have kept the names the same.
Like You have Ruby and Emerald, follow the gem theme, with sapphire, and topaz maybe?
That'll be a new Overclockers mug cheers.
