Cheapest build for wow-mop
3 Apr 2011
York
A friend has asked me to help build her a pc,
Basically the cheapest build that can run WoW on ultra.
(she didnt give a price, just cheapest -.- stupid i know)
She also needs a monitor, keyboard and mouse.
Thinking the new amd trinitys and possibly a 550ti?.
Cheers Phil.
Cheers Phil.
Try squeeze your budget and get a 560 ti. I think a 550 ti is not as fast as a 460. So you could get a 460 which is cheaper than a 550 ti
thanks for the current surjestions
forgot to mention, she doesnt overclock either,
i know.....
i think for wow it needs a GPU really
I think some of you may underestimate just how demanding WOW can be once you've cranked it up to ultra with lots of AA
you can max the graphics on a fairly low end GPU, the only demanding part of wow is from the CPU
Here's a taxi time run from halfhill to dawn's Blossom, with everything set to ultra, 1900*1200 16*anisotropic filtering and 8*AA.
as you can see with minimums of 21.970 and an average of 53.744 it's not too clever and that is without any weather or spawns during the taxi timerun's.
This was done on my i7 920@4GHz with 8MB ram and a GTX470@800MHz
Full size image
Now if my machine can go as low as 21fps during a not particularly intensive taxi flight just image what its like in a raid or even 5 man dungeon, then think of doing it on a machine with only a quarter, maybe a third of the GPU horsepower.
Isn't the latest patch/version of WoW meant to make it more taxing on hardware?? I am not sure if this is a bug,since many WoW players don't necessarily have top end hardware. However,if you drop the settings somewhat,lower hardware should work OK. Luckily the art style of WoW means lower settings don't always look as horrible as other games.
Also,some of the damage meters can really be inefficient and put excessive load on the CPU(can be solved by using a different one).
Yes the latest expansion has increased the load a bit and it does seem to have more detail in the world now. You are quite correct that the age/style of WOW does mean that with a few lower settings it can run well on almost anything from the last few years, but saying that the opening poster did ask for a setup that would run it at ultra settings.
My advice would be a as fast possible CPU with a GPU of around the 560ti/7850 bracket to get it to run on ultra.
its not because of gpu grunt though, its pure single core CPU performance that limits wow, that you could keep the same CPU and swap in a 690 and see only minor performance improvement inside orgrimmar.
every card from a 6870 upwards will give you over 60FPS in wow, dont take me word for it though, http://www.tomshardware.com/reviews/world-of-warcraft-cataclysm-directx-11-performance,2793-3.html
also ive got a gtx670 with an oc i5-750 which is pretty similar on performance to your CPU and i float around the 50 fps mark to most of the time, dropping to the mid twentys in 25 man raids or orgrimmar (when the CPU is extra taxxed)
also recount is a horrible cpu abuser, especially its graphs, taxing the already hard hit single core, as CAT-THE-FIFTH said, try something like tinydps http://www.wowinterface.com/downloads/info16780-TinyDPS.html
BenQ GL2450 24" Widescreen LED Monitor - Black £115.99
Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £99.95
EVGA GeForce GTX 650 1024MB GDDR5 PCI-Express Graphics Card £89.99
OCZ Vertex 2E 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE120G) £52.99
Seasonic S12II 380W '80 Plus Bronze' Power Supply £42.98
Gigabyte H61MA-D2V Intel H61 (Socket 1155) DDR3 Motherboard £39.98
BitFenix Merc Alpha Gaming Case - Black £26.99
GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (GD38GB1333C9DC) £23.99
Samsung SH-224BB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
Sub Total : £423.21
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £17.85
VAT is being charged at 20.00% VAT : £88.21
Total : £529.27
+ £30 for Speakers/Keyboard and mouse.
More expensive than other suggestions, but this will do the job properly.
i3 is better than the for 1-2 core gaming like wow.
24 " Monitor.
SSD, really helps wow with it's in game loading.
Oh Dear, I did have a really long winded post all ready to go but I got distracted by a visitor and now Ive closed the wrong window and lost it all.
Anyway the crux of the matter is that Ive been doing some testing with my GTX470 at various levels of overclock.
800MHz my regular clock and about the speed of a 480/570
607MHz stock clock
500MHz possibly about the speed of a 460
here are my results
so that shows us that a faster gpu than something like a 460 will make quite a difference with the average FPS but the minimums seem to be all over the place, but they dip very low at 500MHz with lots of AA.
ps Ive no idea why the minimums are lower for the 800MHz runs than the 607MHz runs, unless the time of day makes that much difference as the 800MHz runs were done last night and the rest this morning.
anyway apologies to the opening poster if this has taken the thread off track a bit.
607MHz stock clock
here are my results
(Image removed)
Lowering the clock speed of a GTX470 won't simulate accurately GTX460 as it's number of CUDA Cores and memory bandwith are completely different.
When running the benchmark did you see the % of GPU usage?
Running my GTX 670 it's only 20-35%. :)
