Hi,
I got an Asus xonar DG today and installed it without trouble. I mainly got it for the headphone amp and the fact that it had the front panel audio connector. Well that and it was cheap too
Anyway, it is working perfectly, sound is great, much better than the onboard audio and I was very happy until I plugged my headphones into the front panel. Everything sounds awful. It sounds like there is an underwater effect been put on the sound.
I installed the unified drivers to see if that would help, but no difference. When I plug the headphones into the rear of the computer the sound is perfect. It's only when i use the front audio panel that the sound goes bad.
In music instruments are really loud but voice is really quiet. There is no directionality in the sound, like in one song i know there is a guitar section that starts on the right before moving over to the left. but when i listen using the front panel the sound is just in the middle all the time. And over everything there is this echo effect like the music is been played down a well or something. Just in case I checked the effect settings in the Asus control panel but everything was turned off.
Has anyone else had this problem with the Xonar DG? IS it better to use the ac97 or the hd audio connector to connect to the xonar?
IT's really annoying because I wanted to use the front and rear connections and be able to switch between them easily.
