New Build ~ £1500 - £2000
cpr
cpr
24 Nov 2009
Bought a system from OC about 2 years ago and i'm looking to upgrade again, I'm thinking this time I'll build it (or attempt to) myself. Willing to spend between £1500 - £2000, was hoping to stay closer to £1500 though.
I'm a web designer so spend most of my day in Photoshop, need it to run effortlessly. Current system runs it ok, it's starting to lag a bit though when I have a few PSD's / larger PSD's open. I don't play games, other than designing it'll just be used for everyday stuff. Main thing I want is speed (hence the more expensive SSD).
Specification that I've got so far is as follows;
Processor
Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail [BX80619I73930K]
£431.99 inc VAT
Motherboard
ASRock X79 Extreme7 Intel X79 (Socket 2011) DDR3 Motherboard [X79 EXTREME7]
£214.99 inc VAT
Memory
GeIL EVO Corsa 32GB (4x8GB) DDR3 PC3-19200C11 2400MHz Quad Channel Kit (GOC332GB2400C11AQC) [GOC332GB2400C11AQC]
£279.95 inc VAT
Hard Drive 1
OCZ RevoDrive3 240GB PCI-E SSD - (RVD3-FHPX4-240G) [RVD3-FHPX4-240G]
£299.99 inc VAT
Hard Drive 2
Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) [ST3000DM001]
£104.99 inc VAT
Graphics Card
MSI GeForce GTX 660 OC Twin Frozr 2048MB GDDR5 PCI-Express Graphics Card [N660 TF 2GD5/OC]
£167.99 inc VAT
PSU
Corsair Professional Series HX+ 850W '80+ Gold' Modular Power Supply (CP-9020032-UK) [CP-9020032-UK]
£139.99 inc VAT
Case
Corsair Obsidian 650D Gaming Midi Tower - Black [CC650DW]
£149.99 inc VAT
CPU Cooler
Intel Liquid Cooling Solution CPU Cooler (Socket LGA1155/1156//1366/2011)
£72.98 inc VAT
Case Fans
Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack [CO-9050004-WW]
£19.99 inc VAT
CD/DVDRW Drive
Samsung SH-S222BB/RSMS 22x DVD±RW SATA ReWriter (Black/Silver/Biege) - Retail [SH-S222AB/RSMS]
£19.99 inc VAT
Soundcard I use headphones so would it make a difference if I got 7.1?
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp [90-YAA0K0-0UAN0BZ]
£25.99 inc VAT
Total comes to just over £1900. I'm a complete novice when it comes to building so I may have selected incompatible components or gone OTT on certain things.
Help would be much appreciated!
Thanks!
Thanks stulid!
Is the RAM going to make much difference? If for example I switched from the one you've suggested to the one below;
Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Dual/Quad Channel Kit (CMP16GX3M4X1866C9) **SPECIAL** [CMP16GX3M4X1866C9]
Or even one with a higher clocked speed (e.g. 2400MHz), will it be noticeable?
As for the SSD, I've currently got a 75GB one, it runs fast but the only problem with it is that when I'm in Photoshop, it sometimes won't allow me to open more PSD's due to the scratch disks been full (I have usually have around 10GB - 15GB of free space on it). So I think I'd be ok with a 120GB one so I could switch to the one below;
OCZ RevoDrive3 120GB PCI-E SSD - (RVD3-FHPX4-120G) [RVD3-FHPX4-120G]
I'd siding towards the PCI-E SSD due to being double the speed of the one you suggested, which I think will be quadruple the speed of my current one. Again though, I'm not sure if I'm just going OTT here and whether it'd make any difference (or only very minor) at all, I just want it to be very fast and run everything very smoothly!
Thanks again!
Also, in regards to the graphics, the latest Photoshop does use the GPU which the older versions (before CS3 I think) didn't I don't think so I'm not sure what difference this will make? May well be able to switch down to a cheaper card without losing any performance?
How do you copy from your basket so that it displays all the info like below please?
YOUR BASKET
1 x Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £431.99
Total : £1,370.87 (includes shipping : £12.50).
It will be fast, but the Antec P280 case is unbeatable value for money.
It was like £100+ not long ago.
Bigger, supports bigger boards, more fans, quiet.
