- 6 Jun 2012
Hmm, what about if i just buy a motherboard and an I5 2500K and keep my 560TI?
Don't think it'll take the 965, you need a 95W TDP CPU.
While I'd wait for Vishera, I still think you'd have to upgrade sooner that an i5, but I think an i5 upgrade just simply wouldn't be worth it unless you'd went 1155 originally.
Keep what you've got, save money till you can go whole hog upgrade of CPU and GPU when Haswell launches, that way you've got your full spectrum of upgrades.
560TI isn't exactly a slouch, I certainly wouldn't go from a 560TI with Athlon IIX4 to a 7950 with Athlon IIX4.
Interesting results for the FX4170 against the Core i3 3220. I expected the FX4170 to be behind in all the game tests. However,Skyrim is the only one it seems to be really behind in. I kind of expected SC2 to really do well on the Core i3 against the FX4170, as that is lightly threaded like all Blizzard games,but evidently that is not the case.
Depends of what sort of game you play the most. If you are a fan of mmos in general, it would be the best upgrade you could possibly make.Hmm, what about if i just buy a motherboard and an I5 2500K and keep my 560TI?
Also, what difference are going to notice from a 7870 and 7950 at stock? They're hard to distinguish, at this level of performance you'd be hard pressed to tell the difference between a 7870 - GTX680 unless you've got a counter.
That said, I'd still hang tight.
