Man of Honour
- 17 Nov 2003
- Southampton, UK
I'm pondering getting this done but I need to know whether it's worth investigating on my budget or not. Anyone got some rough estimates?
When it comes to my eyes, I wouldn't want to go for any budget options!
Agreed with the above,
You only get one pair of eyes, better to spend the extra if it's needed.
No my spelling is usually this appalling.Did you write this with predictive text?
There's isn't really a budget option, they're very much the same. You can and should check up on results and equipment etc.
But the biggest part of the price is which method you elect and you don't always have the option of the most expensive, it depends on your eyes and what they recommend is the best.
The problem is, the cost decides whether I'll go ahead, so whilst I'd love to get a rolls royce service, I am price sensitive. Anyone got any experience with the lower cost options?
